Car Wont start
when i try to start the car all i hear is rapid clicking noises from the main relay ... fuel pump primes... everything is grounded right.. the battery is good because i have lights and everything .. so any advice would be nice thanks
substitute with a know good battery, you may have enough power to turn the lights on, but not enough to start the car. Jump it or subistitute a know good battery.
You might wanna check youre alternator..you also might want to chek it with a OBD reader...you can borrow it from youre local autozone for free...you just need a license and credit card....
ok i had a friend come over and help me take a look at it ..... i cranked my engine and the main relay clicks and the starter clicks toooo like rapid clicking from both the main relay and starter.. the battery is good and so is the fuel pump it primes..
problem solved ... thanks everyone for their input... the problem was the starter i took it off and just looked at it and i was about to head out to autozone to purchase a new one but my friend said we should just try it again so we put it back and checked all the grounds and i cranked it again and it turned over.
