Question about LSD's!! Type R lsd fits in which cable trannies?
Old Jun 20, 2002 | 11:13 AM
Mazmay's Avatar
Default Question about LSD's!! Type R lsd fits in which cable trannies?
I'm wondering into which trannies a type r lsd will fit?
Cable trannies in particular.
I've got a '92 usdm YS1 cable tranny. Will the type R lsd fit in there?
Any websites with specific information?
Old Jun 20, 2002 | 11:28 AM
REX VT's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (Mazmay)
It should (been done) but I also still have a question about mounting the LSD to the cable tranny's final drive ..
So anyone?
Old Jun 20, 2002 | 12:35 PM
gaskleppie's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (REX VT)
He, rex, je weet toch dat ik zo'n lsd in m'n y2 bak heb.
Het past dus! Je moet wel de hele zooi verbouwen, dus kroonwiel moet afgedraaid worden en ook het sper zelf moet bewerkt worden.
Verder moet de behuizing van de bak aangepast worden anders past het er allemaal niet in.
Vertaal jij dit maar als je kunt!
(sorry guy's. This is dutch........ its to hard for me to explain this in english!)
Old Jun 20, 2002 | 02:35 PM
spettinger's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (gaskleppie)
please try! this LSD talk is gold!
Old Jun 20, 2002 | 02:41 PM
raene's Avatar
Better yet, has anyone done a Quaife into a cable tranny?
Old Jun 20, 2002 | 05:12 PM
E-lude78's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (raene)
I have a friend who had a Quaife LSD successfully installed into his JDM J1 tranny. I never heard any complications after the install. Hope that helps
Old Jun 20, 2002 | 07:08 PM
Mazmay's Avatar
Hehe..grappig. Nederlands. I heb 14 yaar in Hilversum, gewoond, maar nu woon ik in Vancouver.
Old Jun 21, 2002 | 08:10 AM
gaskleppie's Avatar
Leuk topic wordt dit dan!
Ok, I will try.
I've got Integra LSD in my Y2 tranny, so it will fit.
But you have to do some work to make it fit. You must rework the big end gear and the lsd to fit them together. Also you must remove some metal from the tranny housing to make it fit.
Als je kan mag je het ook beter vertalen dan dat ik het kan uitleggen
The first NA B20-Vtec- typeR in Holland!
(maybe the first in europe!)
Old Jun 21, 2002 | 08:15 AM
CHEETAH's Avatar
yes it will fit in any b-series cable or hydraulic, jsut a matter of using the correct c-clip shims which fit in the casing under the carrier bearings ... you need to get the size by checking spacing with feeler guage.
In all the cables, I usually transfer the c-clip from the top casing(bell housing) to the lower piece then install LSD over it and it comes out very close and within tolerance.
also, keep in mind only a gsr from 94+ or a type R ring gear (thats the big gear that fits ont he differential) will fit ont he type R lsd. It can be used with the gear shaft also for 4.4 f/d.
Greg
Old Jun 21, 2002 | 08:23 AM
spettinger's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (CHEETAH)
ok, so the type r lsd fits, with a 94+ integra gsr gear? or the type r gear? these ring clips, are they from a type r or from a stock trans?
Old Jun 21, 2002 | 08:51 AM
CHEETAH's Avatar
Default Re: Question about LSD's!! Type R lsd fits in which cable trannies? (hondaslut #042)
either one Type R or GSR(94+)
the c-clips are in the stock trannies, in the 94+ hydraulic its in the bell housing side (move it to other casing). In the 94+ "square" carrier bearings only. The tapered bearings dont have the c-clip spacers they have a bigger spacer. If your tpye R LSD has the tapered bearings pull them off and put the square ones on ... square are on the stock open diff from cable tranny.
you can buy the shim separately from the dealer ... or ask me nicely
Greg
Old Jun 21, 2002 | 09:33 AM
spettinger's Avatar
consider this a formal request. haha! thanks for all your help man. i have heard that you can get type r lsd's for only like $400? will they have the tapered bearings or the squared off design? thanks again. when is that green monster in the background supposed to run?
Old Jun 21, 2002 | 11:33 AM
CHEETAH's Avatar
ok no problem ...
greg
Old Jun 21, 2002 | 12:10 PM
keithv's Avatar
i have the civic si quaife in my si/zc hybrid tranny. it fit without a problem.
interesting. i have 2 si tranny cases and 1 zc tranny case that all had (at one point) the ring gear rub on the clutch housing of the tranny case. i was going to put the c-clip on the clutch housing on mine so the ring gear wouldn't rub (down the line), but ended up installing it in the bell housing like the manual says to do. i assume you put the clip in the clutch housing to avoid this rubbing problem?
bubba_crx
Apr 5, 2007 09:24 PM
93B17A
Apr 22, 2003 09:10 AM
cornholioEK
Sep 30, 2002 06:46 PM
