help with h23/h22 build
Old Oct 16, 2007 | 09:22 AM
boostedh22lude1's Avatar
Default help with h23/h22 build
im needing to know if h23 pistons fit h22 rods, im getting some wiesco h23 pis. and i dont want to sleeve my h22 the h23 pistons dont rec. sleeving so im wanting to use the h23 pistons/block with the h22 rods, crank any help greatly appr.
Old Oct 16, 2007 | 09:53 AM
NirVTEC's Avatar
Default Re: help with h23/h22 build (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">im needing to know if h23 pistons fit h22 rods, im getting some wiesco h23 pis. and i dont want to sleeve my h22 the h23 pistons dont rec. sleeving so im wanting to use the h23 pistons/block with the h22 rods, crank any help greatly appr. </TD></TR></TABLE>
Do you know where your compression would even be?
Hahahahaha Sure:
Old Oct 16, 2007 | 11:40 AM
preludefien
Guest
Posts: n/a
i think you are confused as hell. your going to have to re-sleeve your block. theres no question about that. use the search button and do some research.
Old Oct 16, 2007 | 11:50 AM
NirVTEC's Avatar
Default Re: help with h23/h22 build (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">i think you are confused as hell. your going to have to re-sleeve your block. theres no question about that. use the search button and do some research. </TD></TR></TABLE>
Maybe you should take some of your own advice too.....
Old Oct 16, 2007 | 01:15 PM
no you dont have to sleeve the block, thats the only reason im even thinking of useing these pistons,the part # is wisk572m87 from nipponpower.com if you want to check.
Old Oct 16, 2007 | 01:22 PM
98vtec's Avatar
moderator emeritus
http://nipponpower.com/product...3E%29
check the note.
reading comprehension.
You cannot run forged pistons in stock FRM cylinder walls unless you have a special coating to keep them from eating up the walls.
krayzieboi213
Jul 7, 2008 07:35 PM
boostedh22lude1
Nov 1, 2007 10:53 PM
jdmaek
Nov 18, 2004 02:21 AM
H22Prelude
Nov 17, 2002 08:55 PM
Smurfylude
Jun 2, 2002 04:06 PM
