TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!!
Old Oct 16, 2007 | 09:13 AM
CaseBone's Avatar
Default TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!!
Here's the deal! I dont have the time or money for this project anymore so I decided I would give up for the sake of my parents sanity...if you have any questions please feel free to PM me or just give me a call.
People on this board can vouch for me as well! http://jdmcity.com/thread1461.html
Cell: 515-490-7087 Ask for Casey!
Head (B18C1 head, Supertech flat faced valves, dual valve springs, titanium retainers) has about 1,200 miles on it only $1000
FRESH Bottom end (B18C1 block, standard bore, P30 pistons, LS balanced rods, LS balanced and magged crank, ACL race bearings, GSR Vtec girdle, Golden Eagle oil squirter plugs, Type R oil pump, ARP main studs, ARP head studs, New water pump) with a two ply headgasket you will have approx. 13:1 comp $1400
Rocket Motorsports M22x camshafts with Buddly Club adjustable cam gears (ALL MOTOR BALLER CAMS) $600
Skunk2 IM port matched and polished+Power 68mm throttle body $350
STR fuel rail, Earl's fittings, Edelbrock inline fuel filter, Adjustable FPR, FPR gauge, Stainless Steel Fuel lines $250
NEW RC 750cc Injectors $325
NEW GReddy Timing Belt $100
Fluidyne Radiator $250
NEW Spoon low temp thermostat+Spoon low temp thermo switch $100
NEW 88rotors Crossdrilled and slotted rotors, PBR semi metallic pads $200
Stock Integra F+R calipers Offer
Front Integra assembly, New wheel bearings, ball joints $150
New inner and outter tie rods $45
NEW Earl's Stainless Steel Braided Brake lines $80
NEW Blox rear control arms $90
Rare GSR gauge cluster SOLD
B17 YS1 transmission, NEW Type R LSD with 4.4 FD ring gear, NEW GearSpeed Carbon coated syncros $1200
Spun 15x6.5 wheels with Falken Azenis 95% tread left LIKE NEW!!!! $700
NEW Walbro 255lph fuel pump $90
NEW F1 9.7lb Flywheel with Stage 3 clutch with 750 miles $200
B&M short shifter $100
Skunk2 shift **** $45
Momo Corse steering wheel with hub $200
CRX seats $100
Megan Racing tie bars, strut bars, C-pillar bar $50
JDM 1 piece headlights $200
90-91 tails $40
NEW KSport fully adjustable coilovers with custom spring rates, 12k F 10k R $650
Ingalls front and rear camber kit $100
P28 ECU $75
JDM thin side moldings $125
ITR Pistons machined to fit LS rods $60
Spoon replica mirrors $45
Rear hatch with glass Offer
Doors Offer
I'm sure I forgot some stuff but this will be updated with prices most likely tomorrow and more parts...so at this point throw some offers....LOWBALLERS WILL BE IGNORED!
Modified by G-Harry at 10:24 AM 10/16/2007
Modified by G-Harry at 10:25 AM 10/16/2007
Modified by CaseBone at 6:16 PM 10/18/2007
Old Oct 16, 2007 | 10:34 AM
MaltBeer's Avatar
Default Re: TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!! (CaseBone)
The build looks great so far, it seems like you've gone very far with it you should keep going lol. But anyway you gotta do what you gotta do I guess.
I'll take the cluster.
You have a PM.
Old Oct 16, 2007 | 11:06 AM
90sedan's Avatar
Default Re: TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!! (MaltBeer)
I'll take the p28 ecu.
You have a pm!
Old Oct 16, 2007 | 05:14 PM
CaseBone's Avatar
Yeah I really wish I could have finished it...I was looking so forward to it and put so much time into it...all things must come to an end...done or not..
PMs replied!!
Old Oct 16, 2007 | 07:46 PM
CaseBone's Avatar
Default Re: TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!! (90sedan)
Old Oct 17, 2007 | 06:06 PM
MaltBeer's Avatar
TTT
Consider the cluster sold budd.
Old Oct 17, 2007 | 09:49 PM
Eg6hybrid92's Avatar
BUMP, I can vouch for this guy.. ...
Old Oct 18, 2007 | 08:38 AM
CaseBone's Avatar
Default Re: TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!! (Eg6hybrid92)
Thanks Mike! bump
Old Oct 18, 2007 | 05:16 PM
CaseBone's Avatar
GSR cluster gone to MaltBeer!
Old Oct 18, 2007 | 09:59 PM
goldenarches69's Avatar
you don't happen to have the distributor do you?
Old Oct 19, 2007 | 07:22 AM
CaseBone's Avatar
Default Re: (goldenarches69)
I have the distributor yes!
Old Oct 19, 2007 | 10:27 AM
SiBuddy00's Avatar
you got mail
Old Oct 19, 2007 | 11:01 AM
CaseBone's Avatar
YOU gots mail!
Old Oct 19, 2007 | 04:21 PM
optiquest242's Avatar
bump it for lookin
Old Oct 19, 2007 | 09:38 PM
CaseBone's Avatar
Default Re: (optiquest242)
thanks mang!
Old Oct 21, 2007 | 11:17 AM
CaseBone's Avatar
sunday recoop bump!
Old Oct 23, 2007 | 09:21 AM
CaseBone's Avatar
Old Oct 24, 2007 | 01:59 PM
CaseBone's Avatar
bumpski!
Old Oct 25, 2007 | 12:45 PM
MaltBeer's Avatar
Bump for a good seller, got the cluster really fast. Thanks!
Old Oct 25, 2007 | 03:39 PM
Cheeech's Avatar
bump
Old Oct 25, 2007 | 05:53 PM
CaseBone's Avatar
Thats good to hear MaltBeer...hope you like it!
Thanks for the bump Cheeech!
Old Oct 26, 2007 | 05:18 PM
MJobe's Avatar
BUMPSKI!!!
good seller
Old Oct 26, 2007 | 05:49 PM
CaseBone's Avatar
Default Re: TONS of NEW parts for DA, B series parts! EVERRRYYYTHING MUST GO!!!! (MJobe)
Thanks Jobes!
No luck on honda-tech either buddy!
Old Oct 27, 2007 | 08:33 AM
SilverRed's Avatar
brake kit disc and pads 200$ to Canada?
Old Oct 27, 2007 | 11:32 AM
MJobe's Avatar
Default Re: (SilverRed)
tttttttttt
