Broken Endlinks??
My girlfriend has a 2000 Accord Sedan (5-speed 4-cylinder), which had a clunking coming from the front suspension. During the state inspection, the mechanic said it was just that the rubber bushings had worn/rotted out, and to replace them at some point. Well, she never got it replaced. I happened to be driving it last weekend, and was going along when I heard a HUGE bang from underneath the car. I pulled over, and looked under the car. The swaybar endlinks look to have snapped on both sides. The bar is clunking around under there, and is only held on by the brackets. Clearly, I have to fix this thing soon.
Is this a common issue? I've never heard of that happening before... Also, does anyone happen to know the part numbers, so I can order them with as little hassle as possible?
Thanks in advance!
Thanks in advance!
You can order any Honda part from http://www.hondaautomotiveparts.com or http://www.slhondaparts.com. It's also very easy to look up what you need and they ship quickly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">Front Right Link 51320-S84-A01
Front Left Link 51321-S84-A01
Parts 4 & 5
correction PART 45
part 4 & 5 are the sleeves and shims for the radius rod
Parts 4 & 5
</TD></TR></TABLE>correction PART 45
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charri »</TD></TR><TR><TD CLASS="quote">correction PART 45
what??? no....
I don't see a part 45 anywhere on that diagram. I do however see parts 4 and 5 and those are the right and left endlinks for the sway bar. The endlinks are bolted to the LCA with nut 21 and to the sway bar with nut 28. The sway bar is also held to the car with bushing 2, bracket 3 and bolt 30.
The radius rods are comprised of parts 6, 8, 10, 11, 13, 14, 15, 25 and 27.
</TD></TR></TABLE>what??? no....
Hondapreludeg
Nov 5, 2023 02:21 PM
nicolaselias
Jul 22, 2011 02:56 PM
