sinking pedal
Old Oct 16, 2007 | 08:06 AM
HASUNA91's Avatar
Default sinking pedal
i have a 92 civic and my pedal sinks all the way down to the the floor. i put new brakes on last week and the pedal still sunk but then it stoped and worked fine. but this morning it started doing it again so im kinda thinkin i might have to bleed them but if that doesnt work then what you guys think is the prob
Old Oct 16, 2007 | 08:11 AM
Probot's Avatar
Default Re: sinking pedal (HASUNA91)
that or your brake master cylinder could be on its way out
Old Oct 16, 2007 | 08:22 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: sinking pedal (Probot)
It's clear pressure is being lost somewhere. A seal could be worn out, or like probot said, the MC could be dying/dead.
Old Oct 16, 2007 | 08:23 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">that or your brake master cylinder could be on its way out</TD></TR></TABLE>
That's NOT the conclusion you should jump to...start with the simple and most likely things...
@ OP:
Squishy pedal means there's air in the lines, now you shouldn't have to remove the brake lines to do rotors and pads, but if you did the wheel cylinders (drums) then you obviously had to disconnect them so there's your problem.
Bleed whatever you disconnected - and you'll be fine.
I would use a vacuum bleeder...but I guess a wrench and 2 pple works fine too...
If you completely bleed it (and you're sure it's 100% bleeded), then, and only then, would I start looking at the master cylinder.
Old Oct 16, 2007 | 09:26 AM
Probot's Avatar
Default Re: sinking pedal (Syndacate)
wasnt jumping to any conclusions chief - the OP stated he was going to try bleeding the system again..if there is no air in the lines and no leaks and there is no pressure i think i can say that its more than likely the MC
jpar196
Aug 2, 2007 03:27 PM
JZA70
Nov 14, 2006 11:16 AM
GsRiNtEeGrA14
Feb 22, 2006 07:25 PM
Tx92AccordExD
May 15, 2003 11:39 AM
