Please help:No Dashlights, no running lights, no tail lights......
Old Oct 16, 2007 | 07:28 AM
CooBreeze's Avatar
Default Please help:No Dashlights, no running lights, no tail lights......
Hi fellas,
I'm new on this board but have used it many times for info. I want to thank you all for the help you have already givin me.
Now as the topic said I don't have and Dash/Cluster lights, no running lights, no tail lights. The tail lights come on if I hit my breaks. And my blinker lights are working fine.
Also I've checked all my fuses and they are all fine. Under the hood is a Light Relay! #s on it are 90-4505-01 and staped on the other side is 1a251.
Now I've checked for that part online and came up with nothing. Could this need replacing? Has anyone else delt with this issue before? Any help would be much apprecated.
BTW It's a 91 Honda Accord LX 4dr
Old Oct 16, 2007 | 08:08 AM
kornfox's Avatar
Default Re: Please help:No Dashlights, no running lights, no tail lights...... (CooBreeze)
Ive heard about this awhile back. I think it was a fuse under the hood. Not in the cabin. Did you check all of you lighting fuses under the hood also?
Old Oct 16, 2007 | 08:21 AM
CooBreeze's Avatar
Default Re: Please help:No Dashlights, no running lights, no tail lights...... (kornfox)
Yes I did, the only one I think it could be is a big black relay type. You can't see if its blown out or not.
Old Oct 16, 2007 | 11:07 AM
kornfox's Avatar
Ive also heard some people with these issues had to replace their flasher relay(s). Im trying to find an electrical schematic for your car. Does everything else function? Headlights hi and low beams, radio, hazard lights?
Old Oct 16, 2007 | 01:02 PM
CooBreeze's Avatar
Sorry took so long, but yes everything else works fine. Even the Park,Reverse,Drive4,Drive3,2nd gear,1st gear lights work in the cluster.
Even my clock works fine.
Old Oct 16, 2007 | 07:08 PM
bseriescrxsi's Avatar
i had the same problem on my 92 accord .....it is a 7.5a fuse in thefuse panel under the hood......recheck your fuses....i believe if your looking at it from the front its a fuse on the top right side of the panel
Old Oct 17, 2007 | 07:14 AM
CooBreeze's Avatar
Default Re: Please help:No Dashlights, no running lights, no tail lights...... (bseriescrxsi)
Nope no luck there, fuse is fine. I figure its got to be some relay switch under the dash board. I've even heard a sound of something fizzling before my running lights would come on a few times before.
But now nothing, hopefully someone on here will know exactly what im talking about.
Funny how my car problems always seem to stump others including my slef.
Modified by CooBreeze at 2:08 PM 10/17/2007
Old Oct 18, 2007 | 07:19 AM
CooBreeze's Avatar
Not sure since Im no car expert, but last nite on my way home my cars idle droped to a point where I had to stay on the gas to keep it running. A few months back I installed a new Main Relay switch, but since I didn't have the proper tools I left the old one in, and hooked up the new one but did not mount it.
Now I'm thinking that the reason is because, attatched is a metal mount witch probaly acts as a ground right?
So im thinking thats probaly why its sizzling out on me. I'm going to unhook the new one and reinstall the old. If this fixes my problem, Im positive thats what is causing your problem also. I'll let you know.
Modified by CooBreeze at 9:25 AM 10/18/2007
Old Oct 22, 2007 | 04:34 PM
CooBreeze's Avatar
Problem solved hope this helps save some of you from getting raped from the dealer ship check my other post.
Go to lighting section.
Old Jun 19, 2011 | 12:14 AM
VancouverHonda's Avatar
hey coobreeze I am currently having this EXACT same issue... exactly what you had.
I have a 2001 HOnda Accord V6 Coupe
What exactly did you do to resolve this issue?
I hope you are still on these forums!!
Old Jun 19, 2011 | 02:36 PM
nus_dogg's Avatar
This thread is back in '07. I'd check your interior fuse.
Old Jun 19, 2011 | 11:13 PM
My Back running lights work (it was the license plate fuse that was burnt out) I put in a new one and those came on...
the Dash lights are still out. I Can see "SRS" D4 D3 D2, P, N, etc.... but the rest is black.
Ive checked every fuse and they are all fine.
Under the hood there is a fuse called "DIMMER RELAY" as circled in red in the picture below. I Checked to see if the fuse for this was burnt but there was no fuse.... and there is no FUSE SOCKET to put a fuse in.... is that normal for 2001 Honda Accords V6 ???
my next attempt will be to check if the actually light bulb burnt out behind the dash.... and after that I will try to locate the MCU (Multiplexer Control Unit) on the drivers side and see if that fried. I found someone online who posted that after he installed his APLINE DECK (JUst like what i have) it burnt out his MCU and he had to get it replaced........
any ideas on any of that??? Cheers thanks
Old Sep 10, 2011 | 01:49 PM
CooBreeze's Avatar
Hay did you fix your problem, mine ended up being the main turn signal light switch. Take the casing off aournd your steering wheel and it should just pop right out replace with a new relay and you should be good to go.
cb
Old Feb 24, 2012 | 06:50 AM
ford16's Avatar
i got a 96 accord and the running lights and dash lights stop working the fuses are good what should i start with
Old Feb 25, 2012 | 05:13 AM
shice119's Avatar
Check the harness behind the steering wheel column cover try plugging it out than back in ,if still no luck check if it is getting power with electrical tester
Old Feb 26, 2012 | 03:54 AM
1991EX's Avatar
My 91 had the same issue, changed the turn signal assy with no luck. After shooting the wires I ended up finding a faulty hot wire to the turn signal switch. Instead of ripping the dash apart I just ran a jumper wire.
Old Feb 13, 2013 | 05:18 PM
cjmguitarist87's Avatar
I had this problem. Still kind of do. Read this post and it helped me through my search. My problem was a loose wire in the plug where the harness hits the under dash fuse box. Tension on this harness over time loosened the wire in the plug. I need to get a new plug from the junkyard( well used) until I find one I just put tension the opposite direction and wrapped it with electrical tape. If it flickers out I just push in on the plug..... Hope this helps anyone who comes across this.
Old Apr 6, 2013 | 10:05 AM
CrystalLandange's Avatar
I have a 1999 Honda Accord and I have no tail lights or dash lights. How the heck do I fix this. I can not drive my car at night and I works nights
Old Apr 7, 2013 | 07:28 AM
nus_dogg's Avatar
Check your fuse.
Old Apr 7, 2013 | 08:06 AM
lhd dc2's Avatar
Check your interior/radio/instrument cluster fuses. Its located on both your driver side and passenger side fuse panel on the side of your dash.
If all fuses are fine. It might be your multiplex control unit. If this video fixes your problem then it is the unit. Its the blue box located on your Fuse box on the driver side.
I had this same issue. And its fixed.
Old Jun 9, 2013 | 01:48 PM
tonyk1286's Avatar
i'm having a similiar problem with my 99 integra. the rear running lights wont work but the brake lights does. can anyone please help me with this issue so i can start driving at night again!! thank you. ps i already checked the fuese under the hood and on the inside too and nothing is blown
Old Jun 10, 2013 | 04:04 AM
Mine was a loose harness where it meets the inside fuse box. Wiggle your wire harness running to the box. Worth a check
Old Dec 14, 2014 | 11:30 AM
jfboy's Avatar
So the man relay switch controls the dahlights and tails?
I have the same problem.
Anyone knows where the main relay switch is on a 2001 accord?
Old Dec 14, 2014 | 01:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Main relay does not have anything to do with the lights.
Old Jan 17, 2016 | 06:46 PM
Bobe2318's Avatar
hi I am new to this site but I have read a number of conversations that have helped me before. I have now ran into trouble trying to figure out why my dash lights, running lights and tail lights don't work, my head lights, turn signals and brake lights all work and on a side note my dash lights only come on when I apply the brake pedal, they light up fine then I release the brake they go away. ive checked fuses, any ideas past that what it could be, I know this a old conversation but any help will be appreciated. thanks
