99 Integra LS auto won't go in revearse
Old Oct 16, 2007 | 07:13 AM
K20ACRX's Avatar
Default 99 Integra LS auto won't go in revearse
Hey, so I searched for a reason why, but a friend I work with has an automatic 1999 Integra LS and it won't go into reverse. Has anyone had this problem, or know what the cause could be, or how to fix it?
Edit: Sorry I spelled reverse wrong in the title.
Modified by K20ACRX at 8:55 AM 10/16/2007
Old Oct 16, 2007 | 09:10 AM
K20ACRX's Avatar
Default Re: 99 Integra LS auto won't go in revearse (K20ACRX)
The car does go into reverse, it just won't back up. All the other gears are fine, but in reverse it is like the parking brake is on. It backs up an inch or two, but then it won't move. Also it doesn't grind or make any noise.
Old Nov 6, 2007 | 06:45 AM
K20ACRX's Avatar
BUMP for help! I just found out she is still having this problem!
Old Nov 6, 2007 | 07:34 AM
AWD Terror's Avatar
Do the RPM's still climb?
Are all the other gears fine?
No to be an ***, but make sure that she is doing everything right....sometimes reverse does not line up with the "R" by the shifter. It might actually be close to "P"
Old Nov 8, 2007 | 07:04 AM
K20ACRX's Avatar
Default Re: 99 Integra LS auto won't go in revearse (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Do the RPM's still climb?
No to be an ***, but make sure that she is doing everything right....sometimes reverse does not line up with the "R" by the shifter. It might actually be close to "P"</TD></TR></TABLE>
Yeah, RPM's climb, no problem driving from start to freeway+ speeds and it lines up with reverse. It acts like it wants to back up, but it feels like the e-brake is engaged.
Old Nov 8, 2007 | 07:24 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20ACRX &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, RPM's climb, no problem driving from start to freeway+ speeds and it lines up with reverse. It acts like it wants to back up, but it feels like the e-brake is engaged.</TD></TR></TABLE>
well, i guess check the ebrake cables and make sure they aren't sticking or wrongly engaging. otherwise, his transmission probably took a crap and it's time for him to get a real integra with a manual transmission. seriously, though, you could find an automatic transmission for an integra for chump change these days.
Old Nov 19, 2007 | 09:00 AM
K20ACRX's Avatar
Default Re: 99 Integra LS auto won't go in revearse (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">
well, i guess check the ebrake cables and make sure they aren't sticking or wrongly engaging. otherwise, his transmission probably took a crap and it's time for him to get a real integra with a manual transmission. seriously, though, you could find an automatic transmission for an integra for chump change these days.</TD></TR></TABLE>
Thank you for the advise, she got it fixed. Guess what it was......so she changed out the front calipers herself and somehow had a loose bolt that would catch when she put it in reverse. I didn't talk to the shop, but they charged her $50. LOL!!
redbull99
Sep 12, 2015 09:04 PM
dc2moi
Jul 1, 2008 12:51 PM
