advancing timing
Old Oct 15, 2007 | 11:53 PM
kixcrx's Avatar
Default advancing timing
if i were to advance my timing by moving distributor will it really help and also is it true if i were to advance it i would have to use high octane fuel all the time
Modified by kixcrx at 3:09 AM 10/16/2007
Old Oct 16, 2007 | 12:17 AM
Duane_in_Japan's Avatar
Default Re: advancing timing (kixcrx)
Advancing does help, until it starts knocking, higher octane retards the knocking until a higher advance, even better, if your engine has a knock sensor it may very well feel the knock and retard your advanced timing and higher octane right out of the picture, no KNK sensor and blow up your motor, or at least one piston. Get a tunable ECU, have a MAP built and dyno it, you can tune a MAP but you cant tune a fish.
Old Oct 16, 2007 | 09:38 AM
kixcrx's Avatar
Default Re: advancing timing (Duane_in_Japan)
so i should just leave it how it is instead of moving it and mess something up right now its on the middle line in the pulley you know like how there is 3 lines ||| mines in the middle one is that good
Old Oct 16, 2007 | 11:27 AM
91-ef-hatch's Avatar
It all depends on how much you advance it.
Ive had mine advanced just a little for a while and have had no probs.
Just dont go overboard with it
Old Oct 16, 2007 | 11:44 AM
94 Supra TT's Avatar
You could advance it 2 degrees, the line furthest from the white tdc line and still be in spec.
Old Oct 17, 2007 | 10:49 PM
kixcrx's Avatar
Default Re: advancing timing (94 Supra TT)
right now my timing is at 16 the middle line from the 3 lines if i move it to 18 which is the line closest to front bumper of car that will be advancing right just like how it shows in pic
Modified by kixcrx at 3:45 AM 10/18/2007
codenamezero
Sep 11, 2011 09:55 AM
batboyvaj
Jun 21, 2009 06:52 PM
be18see1
Apr 9, 2008 05:32 AM
dean2
Dec 27, 2006 11:21 AM
sleeperb16a
Nov 19, 2004 07:32 AM
