help on f20b swap
i got a 99 accord, and i just got a jdm f20b motor to put in, on my motor (f23a4) the O2 sensor is on the exhaust manifold , and on the f20b the 02 sensor is down on the downpipe near the Cat. I look around and cant find any answer if the H22 usdm (97 up) aftermarket header will fit, or any answer on how i wound make it work and pass smog test. I need help
Oh yeah and i found out that there is two type of header for the H22, swich one do i need the one for a SH or the stander one.
Modified by toulor84 at 12:19 AM 10/16/2007
Oh yeah and i found out that there is two type of header for the H22, swich one do i need the one for a SH or the stander one.Modified by toulor84 at 12:19 AM 10/16/2007
will the header bolt up to my stock exhaust system? i understand that a h22 and a f20b is the same thing, but if i'm not mistaking the h22 is a obd1 and the f20b is a obd2, will it still work, and on my f23a4 it has "2" 02 sensor, does the f20b have 1 or 2 02 sensor stock, how do i bypass the other sensor.
Modified by toulor84 at 9:00 AM 10/17/2007
