USDM 5 lug conversion Complete. MD mid-atlantic
Sweet a daughter Ill think about it. I wanted a boi. LOL
If you already have an ek with rear disc, you wont need anything. Instead of installing the complete swap Omit the front upper control arms out of the install and use the ek uca's. You can use the ebrake cables on your current disc instead of the eg/dc ones to make the ebrake work. Shouldnt have to buy anything other then brake fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkvn77 »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> Sweeeeet!
I'll let u knw. i maybe wanting it w/o wheels as well....
Your gonna need ek rear disc brake cables, and of course brake fluid. Other then that you won't need anything. Its a usdm one so you can use your stock axles. -_-
PMed....just making sure this kit includes everything I need.
Front: knuckle/hub assembly, calipers,rotors, upper control arms.
Rear:trailing arm assembly, rear caliper, rotors
I do have drums so ill need new e brake cables. Come with eg/dc cables that will fit on my ek?
master cyclinder and booster
4040 proportioning valve.
Try to get back to me ASAP so we can close this deal. I can meet half way. or shipped. Thanksss.
every thing you stated except the propo vavle, booster, and master cyl.
I also have a gsr booster, mc, and propo valve if your interested. I would recommend the 00 si propo vavle for an ek (makes life easier you wont have to mess with all the hard lines). The gsr booster and mc would work fine with the brakes.
For the ek e brake cables, You'll need ones for a rear disc model.
As for the s2k rims they are both front rims.
