help >>> (Dropzone) coilovers question
Old Oct 15, 2007 | 03:29 PM
type_one1's Avatar
Default help >>> (Dropzone) coilovers question
This past weekend I installed dropzone coilovers on my DA (90 RS) and as per what my dumb *** was able to see is that all coilovers were the same sizes ..
I put the front ones all way down and the rear only half way down and this is where the problems is , the rear is only half way down and its actually sitting way lower then the front that all the way down ..
Did I do anything wrong ??? I even removed the bump stop on the front and still have the same problem ..
PS : I am running the coilovers on stock shocks/struts ..
Thanks..........
Old Oct 15, 2007 | 03:57 PM
deadmemoryy's Avatar
Not to be a dick but it's probably because it's Dropzone did you make sure you put the rears on the rear and fronts on the fronts? That could be it.
Old Oct 15, 2007 | 04:10 PM
dizzzane's Avatar
Default Re: (deadmemoryy)
As dead memory said, are you sure you don't have the fronts and rears swapped?
Old Oct 15, 2007 | 05:09 PM
type_one1's Avatar
Default Re: (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">As dead memory said, are you sure you don't have the fronts and rears swapped? </TD></TR></TABLE>
I dunno , I was actually thinking the same thing but when I got the coilovers they all look the same ...I used the two first ones in the box in the frony and the last two on the rears ..
do you think thats what i did ???
Old Oct 15, 2007 | 05:17 PM
dizzzane's Avatar
Default Re: (type_one1)
Sounds most probable. Hate to make you take the coilovers off again, but I'm pretty sure that is the problem.
Old Oct 15, 2007 | 06:19 PM
type_one1's Avatar
damn man.. well I guess I have to do that tomorrow ....
Thanks for all the help .......
TheGreatOne84
Suspension & Brakes
11
Sep 17, 2007 10:14 AM
civic_tuned
Suspension & Brakes
11
Feb 21, 2006 07:41 PM
FalkenSiR
Suspension & Brakes
Jan 3, 2006 04:06 PM
pr0jektdc2
Feb 15, 2004 01:56 PM
