Honda rod bearing chart for an ITR
I pulled these numbers of the rod and crank.
ITR Rods: 22 22 23 22
ITR Crank: W3 W3 X3 W3
So is this enough info for the rod bearings
also, how do I find out what main bearings I need for the ITR crank ?
[Modified by TRuST, 2:51 PM 6/24/2002]
also, how do I find out what main bearings I need for these crank ?
Rod codes are W22-W22-X23-W22 assuming you put them in the same order.
You are missing one number for the main code.
Should be 5 numbers on the crank and 5 letters on the bottom of the block
on the transmission side.
So these are the rods: W22 W22 X23 W22
Do you think I need to plastic guage them ? The rods and crank are brand new.
On the crank am I looking for an engraved letter and the letters block to get the main bearings.
I got the codes for the crank.
main bearings: d3 c3 c3 c3 d3
Rods: W22 W22 X23 W22
Can someone look up on a honda bearing chart to tell me what colors I need ?
[Modified by TRuST, 2:25 PM 7/8/2002]
OK, I got the color that I need but I need to confirm one mroe thing.
W23 is a Yellow/Green => Does this mean the the top bearings is yellow and the bottom bearings is Green ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRuST »</TD></TR><TR><TD CLASS="quote">OK, I got the color that I need but I need to confirm one mroe thing.
I would say that is a safe assumption.
well bringing this back from the dead once again, I am also needing new bearings for my type R and this is what Iv got and it doesnt match up with my haynes manual....
main bearings: c3 c3 a3 c3 c3
rod bearings: y25 y25 y25 y24
I got the ccacc from the block and there was y3 stamped on the crank all the way across....please let me know if this is correct and if anyone can tell me what the color codes are for these I would appreciate it.
thanks
thanks
EF9_TryMe
Oct 23, 2012 08:08 AM
Ratman
Apr 10, 2006 02:23 AM
turbotypeR@SPEC
Feb 16, 2006 07:36 PM
