Brake line questions...
When I convert my 00 cx hb to ITR 5 lug...what SS brake lines will I order? For the hb or the ITR? Also, the hb has rear drummies on it now.
thanks-J
thanks-J
I'm pretty sure the connections at the caliper are the same for all Hondas and Acuras. Get the Si kit and that way, you know you've got the proper ends for rear calipers and the proper length lines for your chassis.
You could also try Brake Parts Warehouse. They make their lines in house, to your specs if necessary, and they're less expensive than the prepackaged kits, like Goodridge. That's where I got mine. Sorry, it's been a while, i don't have the number. Try and internet search if you'd like more info.
EK SI will work fine.
Si works fine, that's what I'm using
Make sure they have enough tension in the front. Mine rubbed on my wheels and wore a hole..
not a good thing
not a good thing
redboost10
Suspension & Brakes
Oct 30, 2008 08:55 AM
hondacivichatch
Jan 19, 2006 03:41 PM
