99 Si: car bogs and doesnt idle correctly
Old Oct 15, 2007 | 11:49 AM
vtecnique69's Avatar
Default 99 Si: car bogs and doesnt idle correctly
having a problem on a 99 Si... codes as follows from my scanner tool:
Cyl. 1,3 & 4 misfiring
random misfire
and manufacturer ingition control system or misfire.
just replaced the plugs, cap, rotor, and coil. i really don't have a way to get to the injectors at the moment.
he said it happened suddenly when driving on the expressway - car just started bogging and would not stay on while idling...
before i go ripping apart the fuel system... any ideas?
Old Oct 15, 2007 | 11:57 AM
White_Snow's Avatar
Default Re: 99 Si: car bogs and doesnt idle correctly (vtecnique69)
You check the plug wires also? One of mine rusted out and i got a rough idle (didn t lose 3 cylinders though)
Old Oct 15, 2007 | 12:09 PM
mvp33d's Avatar
i had the same problem with my 93 si w/ gsr motor, i had to replace the fuel pump assembly and everything was fine after that. good luck
dchampn
40
Feb 11, 2013 02:36 PM
Deviant117
Jul 31, 2012 04:53 PM
Spo0NFed E M 1
Jun 27, 2006 03:44 AM
jdkornlp
Sep 6, 2005 05:12 PM
Anthonyl469
Jun 17, 2004 09:58 PM
