traction bar bolts are STUCK! show me da way
ok so i had a cheap ebay traction bar and i hit the biggest pot hole damn rain well anyways my tration bar snapped broke so i got a full race one now BUT the bolts broke off inside the chassie i wiggled most of them out but i think i need to take it to a shop some where in the east bay does anyone know a good shop that wont charge an arm n a leg?preferably in concord pittsburg area?
thanks 4 ur help bump if u view
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9vlad »</TD></TR><TR><TD CLASS="quote"> thanks 4 ur help bump if u view
If it is bumped, which is against the rules whoever bumps will loose %
</TD></TR></TABLE>If it is bumped, which is against the rules whoever bumps will loose %
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 »</TD></TR><TR><TD CLASS="quote">why not try some easy outs???</TD></TR></TABLE>
tried that and my buddy said i might have to cut the frame too get too it but i look at him like '' cut my frame? hell no!'' he said easy out wont help
you might have to drill it out(step drilling,ei small to bigger) and use a tap and dye to re thread it, you might have to use a larger tap/bolt.
if this sounds like a bit much, you might contact a machine shop to see if they have any tricks, or the ability to remove it. maybe they have some long easy outs or something, or maybe they/you could make a longer one?
good luck
good luck
get a chissel or center punch and start tapping it out with a heavy hammer. the same way you pull an ignition switch.
if that doesnt work drill into it and get a reverse thread bolt remover and tap that **** in with a hammer and use vise grips to turn.. once it starts you are basicly done it just takes time
and maybe if you are really lucky you can weld another bolt to the broken one thats still in there and voilla
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog »</TD></TR><TR><TD CLASS="quote">you might have to drill it out(step drilling,ei small to bigger) and use a tap and dye to re thread it, you might have to use a larger tap/bolt.
i agree take the bolts to home depot and find ones that are a little bit larger in diameter. buy some drill bits and a tapping tool. should cost you under $75 for the whole thing. or take it to any shop and they will do it for you for a little more money. THAT WHAT YOU GET FOR BUYING EBAY CRAP. sorry if that comment was a little harsh but its true!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9vlad »</TD></TR><TR><TD CLASS="quote">i didnt know it was ebay but i corrected my mistake now i got full race</TD></TR></TABLE> good you learned your lesson! class dismissed
I'd say go for the reverse threaded bolt idea. Drill a hole in the center of the snapped bolt, tap it, thread in a reverse threaded bolt, heat the old bolt stud up with a torch, and start turning
ef9vlad
Sep 11, 2007 05:08 PM
GUNNER666
Aug 5, 2005 05:16 PM
