HElP ME CHANGE CONNECTING ROD BEARING AND PISTON RING
Hy any body can help change my Integra GSR 1995 connecting rod bearing ang piston rings with a manual or a dicribe instructions list.PLEASE NEED HELP
Or just tell me what to do.
Thanks
Thanks
Hondahookup.com for your manual. http://www.evans-tuning.com has a complete write up of the correct way to build/rebuild a engine.
if you spun a bearing DONT just change your bearings, the rod/or crank is damaged from the 1st spun bearing, you need to remove the crank and have a machine shop turn it, then you need over sized bearings.
eklum
17
Apr 30, 2006 07:40 AM
