Cam for y7...
Old Oct 15, 2007 | 05:20 AM
EFstyle's Avatar
Default Cam for y7...
What are my options for y7 cams?? I did a little shearching but didnt come up with too much
Old Oct 15, 2007 | 06:55 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Cam for y7... (EFstyle)
shafts or gears?
if you`re talking about camshafts, try deltacam.com they make regrinds.
more info would help, you want a turbo cam? what`s your setup, etc.
Old Oct 15, 2007 | 08:49 AM
96 EX's Avatar
Default Re: Cam for y7... (BrokeA$$Pinoy)
Forget the y7 if anything slap a y8 head w/ a crower stg 2 cam. Still retain stock idle with a little boost in performance from the vtec an the cam.
Old Oct 15, 2007 | 09:31 AM
hondamark35's Avatar
yeah i looked into this myself, and found that swaping the head is a much better option, unless you are completely set out to prove that a y7 can make power, which would involve extremes in every area... aka a race or drag set up.
if you go for the y8 head you can get a valvetrain kit that makes really great power from akmee.com
Old Oct 15, 2007 | 09:35 AM
Syndacate's Avatar
Don't bother, it's not worth it all if that motor is stock (and I/H/E still makes it stock).
Modified by Syndacate at 8:08 PM 10/15/2007
delsoldrew
15
May 31, 2020 11:29 PM
1slowEF9
Nov 14, 2006 01:21 PM
BIGTUNA
Mar 14, 2006 02:22 PM
BauleyCivic
May 14, 2003 02:32 PM
