need help... H22 swap finished but wont rev???
Old Oct 15, 2007 | 01:25 AM
JDM-CD5H22's Avatar
Default need help... H22 swap finished but wont rev???
k so we finished the h22 swap in my 95 accord plugged in a chipped p 28 switched wires a6 and a11 went to drive it and absolutely no power... it revs to about 6 and it takes longer than it did with the single cam to get there... totally stuck please help
Old Oct 15, 2007 | 02:33 AM
JDM-CD5H22's Avatar
Default Re: need help... H22 swap finished but wont rev??? (JDM-CD5H22)
we are throwing codes 10, 14, and 6... and the srs is blinking... 10 is iact which is hooked up and working, 6 is ect which is fine and, 14 is iacv which is also workin fine... wiring effed up on the ecu??? or am i forgetting some
Old Oct 15, 2007 | 12:21 PM
94civic18's Avatar
bump for an answer for this kid.
Old Oct 15, 2007 | 02:59 PM
raceACCORDingly's Avatar
have you tried it with a p13?
Old Oct 15, 2007 | 03:12 PM
TheMuffinMan's Avatar
He knows where you live!
I vote bad ECU
Old Oct 15, 2007 | 04:02 PM
awdgsx96's Avatar
Try a P13
Or check to make sure your IACV and TPS are in the right places. They can plug into each other
Old Oct 18, 2007 | 10:35 AM
JDM-CD5H22's Avatar
Default Re: (Mr Wonderfull)
thanks... tried a p13, p06 (no vtec obviously), stock f22 ecu, all the same with the shitty idle... figured out the timing belt jumped a tooth... now it raps out but vtec is no where to be found... trying to figure that one out, going to start by cleaning the oil screen and check wiring... iacv was bad by the way... thanks for the replies and any new info would be awesome
Old Oct 18, 2007 | 03:22 PM
JDM-CD5H22's Avatar
vss is good and accurate, and the tach works... so waiting for it to cool down and then cleaning the screen
tjmutlow
Mar 13, 2012 09:25 AM
dschwantz
May 18, 2008 02:50 PM
RooSter
Nov 22, 2007 04:31 PM
lcaruca97
Sep 3, 2004 07:44 AM
H22edAccord
Apr 18, 2004 05:29 PM
