help!! passenger side rotor spins, driver side rotor doesnt
my car in jack stands without the front wheels. just replaced with new axles. when i accelerate.reverse etc. the passenger side rotor spins. the driver side doesnt. is this normal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">my car in jack stands without the front wheels. just replaced with new axles. when i accelerate.reverse etc. the passenger side rotor spins. the driver side doesnt. is this normal? </TD></TR></TABLE>
If your rotor wasn't spinning, your car isn't moving. Period.
You car like most is not posi-traction, the other wheel helps keep the car from side slipping when you do a burn out, its normal, thats why you cant drive in deep snow or mud, you have a one wheel drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan »</TD></TR><TR><TD CLASS="quote">You car like most is not posi-traction, the other wheel helps keep the car from side slipping when you do a burn out, its normal, thats why you cant drive in deep snow or mud, you have a one wheel drive.</TD></TR></TABLE>
True. I thought the OP meant when the car is on the ground.
Yes, in that case, its perfectly normal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">my car ran. its just when it was on jack stands only the passenger side was spinning. </TD></TR></TABLE>
then yes, you are good 2 go. Normal.
R-81 Coupe
Nov 23, 2006 09:49 PM
