need help, problem with swap
Old Oct 14, 2007 | 07:51 PM
billy_thekid's Avatar
Default need help, problem with swap
so this weekend we did a swap in my rex, we put in the sohc zc. we wired everything up, it starts and runs, but it only revs up to around 3000rpms and on the computer the crankm sensor code is flashing. we cant figure out what to do mabey we wired it wrong...
any ideas,
Old Oct 14, 2007 | 08:04 PM
mini-me-power's Avatar
you might as well start with the wiring if your questioning yourself.
Old Oct 15, 2007 | 04:17 AM
markviiisvt4's Avatar
You prolly have the wires reversed for the number one position sensor. The C1 and C2 wires on the ECU on the dis they are blue and blue/green. the only two wires you had to run to the distributor.;
Old Oct 15, 2007 | 09:16 AM
Default Re: need help, problem with swap (billy_thekid)
well i guess we r going to completely re wire it.
thanks
Justin95-si
Apr 25, 2012 10:56 PM
Dark91zc
Oct 10, 2004 08:11 PM
skrappy
Nov 28, 2003 09:02 AM
WhiteDSM520
May 5, 2003 04:03 AM
CRXBoy
Jan 10, 2003 08:03 AM
