v-tech help
I was wondering if any one can help me on my v-tech its not kicking in,and the speedodmeter just stays at zero but my friend said that i need the v-tech fluid in order for it to work. so can any one help me where I can get he fluid? and how many quarts do i need? and how much would it cost me?. i have v16 type-r i tried the p28 and the speedodmeter and v-tec still doesnt kick in.
thank you. tim
Modified by reddelsol6275 at 8:15 PM 10/14/2007
thank you. tim
bwhahah VTEC fluid. thats a new one.
check your VSS (vehical speed sensor) on your tranny if your speedo isnt working.
check your oil leve as well, and then examine the VTEC solenoid after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddelsol6275 »</TD></TR><TR><TD CLASS="quote"> I was wondering if any one can help me on my v-tech its not kicking in,and the speedodmeter just stays at zero but my friend said that i need the v-tech fluid in order for it to work. so can any one help me where I can get he fluid? and how many quarts do i need? and how much would it cost me?.
thank you. tim </TD></TR></TABLE>
... you also need to replace your muffler bearings while ur at it, other wise you'll leak vtec fluid out of your headlights, and your motor will hydrolock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatpride111 »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_Sleeper »</TD></TR><TR><TD CLASS="quote">
Cool Cool Island Breezes. BOY-EE
You've all been had.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddelsol6275 »</TD></TR><TR><TD CLASS="quote"> I was wondering if any one can help me on my v-tech its not kicking in,and the speedodmeter just stays at zero but my friend said that i need the v-tech fluid in order for it to work. so can any one help me where I can get he fluid? and how many quarts do i need? and how much would it cost me?. i have v16 type-r i tried the p28 and the speedodmeter and v-tech still doesnt kick in.
How did you guys not see that this is a hilarious and elaborate prank? ONLY A GENIUS could have thought of this. :sigh: I wanna be a genius.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">The turbo or exhaust making more power was a much better prank than this weaksauce.</TD></TR></TABLE>
lol hey no offense...but you did fall for this one.
i just use regular blinker fluid, it works as good as the expensive vtak fluid.
oh and make sure you have a whole 2quarts in there or you will only get half vtak.
this is where i order mine:http://kalecoauto.com/index.php?main...&products_id=6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">lol hey no offense...but you did fall for this one. </TD></TR></TABLE>
lol its just that Ive seen someone that was really serious about trying to get their hands on vtec fluid for it to work. He was not joking one bit lol. I kinda felt bad for the guy but it was hilarious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddelsol6275 »</TD></TR><TR><TD CLASS="quote"> I was wondering if any one can help me on my v-tech its not kicking in,and the speedodmeter just stays at zero but my friend said that i need the v-tech fluid in order for it to work. so can any one help me where I can get he fluid? and how many quarts do i need? and how much would it cost me?. i have v16 type-r i tried the p28 and the speedodmeter and v-tec still doesnt kick in.
thank you. tim
Modified by reddelsol6275 at 8:15 PM 10/14/2007</TD></TR></TABLE>
oh snaps y0!
K-SWAP
V-SWAP
IBTL!
thank you. tim
oh snaps y0!
K-SWAP
V-SWAP
IBTL!
LMFAO.....
my god ,this kid needs some help but where can we start , alot of bad info here i dont know exactly whats the problem..
the speedmeter doesnt have anything to do with your vtec, just drain the oil you have a put a new 4 quater of oil in with a new oil filter and unplug your ECU and your battery for couple minutes then put it back let the car run for a lil bit and then go and beat on it to see if v-tec engage....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lscivic1999 »</TD></TR><TR><TD CLASS="quote">LMFAO.....
the speedmeter doesnt have anything to do with your vtec, just drain the oil you have a put a new 4 quater of oil in with a new oil filter and unplug your ECU and your battery for couple minutes then put it back let the car run for a lil bit and then go and beat on it to see if v-tec engage....</TD></TR></TABLE>
Wrong. The speedometer does have something to do with vtec not engaging. If the speedo isnt working than no vtec. The car must be moving at at least ~15mph for vtec to engage which the ecu would not recognize that without a working speedometer.
