crower stage 1 cams
Old Oct 14, 2007 | 04:39 PM
lsteg94's Avatar
Default crower stage 1 cams
had a couple ?'s about this i no there have been alot of post about this.....i have a 94teg ls i wanna get stage1 cams and i heard crower are one of the best can u guys let em no if this is right and how easy it is to install them im still researching on them and let me no what all i would need to put them in thanx
Old Oct 14, 2007 | 07:59 PM
bigkvn77's Avatar
Default Re: crower stage 1 cams (lsteg94)
Crower cams are good cams. I haven't had any problems with them.
About installation. If you can do a timing belt you can change cams. Just follow the steps as if you are going to do a timing belt. After everything is removed remove the cam caps and replace the cams. Make sure you lube the cam. Line up the timing marks and put the timing belt back on. Before putting everything back together. Make sure you adjust the valve lash as to crower spec's. Rotate the crank 4 complete rotations, and recheck your timing marks. If everything is well. Slap it together, and hf.
IMO if you feel comfortable ripping your engine apart (Or, can borrow someone who does). And are able to have your car down for a few days. I'd just save up a few more hundred and do a ls-vtec. It will raise your compression, and give you a better cams for just a lil more of your savings. You will be much happier power wise going that route. thats my 2cents.
Steeve_Civic
Jul 24, 2012 10:21 PM
Bumteg
Feb 3, 2009 11:00 AM
blowme
May 17, 2005 04:48 PM
wangan_DA9
Nov 1, 2004 06:39 PM
movenu
17
Feb 21, 2004 07:06 PM
