Stock Clutch?
Old Oct 14, 2007 | 12:50 PM
Tyte-S's Avatar
Default Stock Clutch?
How much Hp is the stock clutch good up to?
Old Oct 14, 2007 | 12:57 PM
risktypeS's Avatar
Default Re: Stock Clutch? (Tyte-S)
mid 200's maybe i would at least say 250 and below.. but not 100% about that. i just know when you start making power.. you need to change the clutch because it will not last.
Old Oct 14, 2007 | 01:54 PM
iownanrsx's Avatar
your planning on turboing correct?
stock clutch will not last you ... consider the Competition stage 4 .. its totally streetable and is decently priced ... ive had no issues with it at all and ive im hard on it ... consistent 1.7 - 1.8 60 foot times
and its more then enough clutch for 400 whp and isnt to violent at the sametime .. going overboard with clutches breaks things (tranny)
consider a lsd at the sametime ... (quaife)
kent
Old Oct 14, 2007 | 02:05 PM
Tyte-S's Avatar
Default Re: Stock Clutch? (iownanrsx)
Yeah. The first tune should be coming this December, and it will most likely put me around 250-270whp. Next summer, during summer break, i will be building the block and getting it retuned and shooting for 400whp, by that time i hope to have upgraded the clutch/flywheel set up. But i did not plan on upgrading it for the first tune. BTW, the car is not a DD, mainly a weekend driver
Old Oct 14, 2007 | 02:06 PM
Tyte-S's Avatar
can you post links for the clutch you have and the LSD?
Old Oct 14, 2007 | 02:26 PM
iownanrsx's Avatar
check PM
Old Oct 14, 2007 | 05:11 PM
Tyte-S's Avatar
Recieved. Greatly appreciated. Thanks man
Old Oct 16, 2007 | 08:24 PM
Tyte-S's Avatar
Default Re: Stock Clutch? (PimpYouAll)
Yup.
Old Oct 17, 2007 | 06:56 PM
Slo_RSX's Avatar
I have 259 at the wheels and my clutch is starting to slip after 6 months.
Old Oct 17, 2007 | 07:05 PM
Tyte-S's Avatar
Default Re: Stock Clutch? (Slo_RSX)
Im not to worried about it, the sooner it goes the sooner i get to upgrade.
Old Oct 17, 2007 | 07:54 PM
teamXXXrob's Avatar
Teamxxxracing.com
A stock clutch lasting all depends on how you drive your car. My stock clutch went quickly after one summer of drag racing the car and it was basically stock... i've since then upgraded to the Exedy stg 2 clutch and now have the Clutch Masters FX400 4-puck.
Need any pricing on clutches, give me a shout.
Old Oct 24, 2007 | 02:06 PM
Jeenyusss's Avatar
Default Re: (teamXXXrob)
me= revhard kit @10psi- 230ishwhp
exedy stage 1 with no problems
i highly suggest changing clutch if you are doing any semi-serious power adders. its a PITA job, took me a whole weekend, but worth it in the end
Old Oct 24, 2007 | 03:17 PM
risktypeS's Avatar
Default Re: (Jeenyusss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeenyusss &raquo;</TD></TR><TR><TD CLASS="quote">me= revhard kit @10psi- 230ishwhp
i highly suggest changing clutch if you are doing any semi-serious power adders. its a PITA job, took me a whole weekend, but worth it in the end</TD></TR></TABLE>
100% agreed. Took out my tranny, changed clutch, pressure plate and put in the dc5-R LSD. Took the whole weekend. I was hating every bit of it.
Now i have another rsx-s i'm not looking forward to changing the clutch and putting in LSD again. Going with a queef i mean quife this time lol. I don't think the stock LSD can handle 500 hp when i get there, so it'd be pointless to go typeR lsd.
Old Oct 24, 2007 | 10:50 PM
Tyte-S's Avatar
Default Re: (risktypeS)
Looking to hit 400whp eventually. I guess I plan to rock the stock clutch untill it ***** itself then replace it in the ensuing aftermath. BTW, how much did it cost to get the dc5-R LSD?
Old Oct 26, 2007 | 12:45 PM
thrty8street's Avatar
Default Re: (Tyte-S)
How hard is it to install an LSD on an rsx? Is there a DIY anywhere?
Old Oct 26, 2007 | 01:47 PM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think the stock LSD can handle 500 hp when i get there, so it'd be pointless to go typeR lsd. </TD></TR></TABLE> How much is the DC5-r LSD good up to?
Old Oct 26, 2007 | 02:08 PM
risktypeS's Avatar
i'm not sure i just know 500 hp is to much for an OEM LSD. My guess is maybe 350-400.
Old Oct 26, 2007 | 08:30 PM
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to install an LSD on an rsx? Is there a DIY anywhere?</TD></TR></TABLE>
Old Oct 27, 2007 | 11:20 PM
risktypeS's Avatar
Sorry didn't see your post and it's not hard but a PITA because you have to take out the tranny and that's the PITA. I don't know if there is DIY's tho.
Old Oct 28, 2007 | 07:37 AM
WhiteOnRice's Avatar
You should make a how-to since it's a common question. Even if you don't have pictures. It'll be better than what we have now.
Old Oct 28, 2007 | 08:46 AM
risktypeS's Avatar
Default Re: (WhiteOnRice)
My roommate was the one who showed me how to do it. Came out to be pretty simple. If i get a quaife lsd anytime soon i'll see if i can put one together.
93CivNewB18
Jan 8, 2009 02:06 PM
pjr710
Jul 23, 2008 09:53 AM
98cwitr
Dec 9, 2002 11:43 PM
StinkyTofu
May 20, 2002 05:11 PM
