Leak onto pedals and fuse box!
Old Oct 14, 2007 | 12:23 PM
GoFastTshirts.com's Avatar
Default Leak onto pedals and fuse box!
hey guys I have a 91 CRX Si and when it rains real hard i get water all over the pedals and the fusebox right above. Where can this be coming from? Thanks
Old Oct 14, 2007 | 12:50 PM
foress_89's Avatar
My guess is front the area under the windshield, under the wipers...
Old Oct 14, 2007 | 05:46 PM
Hi-Tech Honda Girl's Avatar
Default Re: Leak onto pedals and fuse box! (GoFastTshirts.com)
im pretty sure i can help. lol. most likely u have a hole in ur fire wall. this happens to alot of people. look under ur hood on ur fire wall n see if u have any random holes. if so...just get something to plug the hole. pretty simple. right? i hope thats all it is.
Old Oct 14, 2007 | 06:44 PM
Crx dude's Avatar
Default Re: Leak onto pedals and fuse box! (Hi-Tech Honda Girl)
Could be a sunroof drain leaking into the car.
Old Oct 15, 2007 | 03:36 PM
thanks guys i will keep you updated
Old Oct 15, 2007 | 08:05 PM
ScottEK's Avatar
Default Re: Leak onto pedals and fuse box! (Crx dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx dude &raquo;</TD></TR><TR><TD CLASS="quote">Could be a sunroof drain leaking into the car.</TD></TR></TABLE>
I had this same problem at one point, right above my hood release cable. There is a sunroof drain that detaches at this location.
Old Oct 15, 2007 | 08:49 PM
503_EF9's Avatar
Default Re: Leak onto pedals and fuse box! (ScottEK)
its kinda just a guess and check bro.
Old Oct 15, 2007 | 08:52 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK &raquo;</TD></TR><TR><TD CLASS="quote">
I had this same problem at one point, right above my hood release cable. There is a sunroof drain that detaches at this location. </TD></TR></TABLE>
x2
Old Oct 16, 2007 | 03:02 AM
DAP91Si's Avatar
Next time you have the leak, open the vent on the drivers side that allows outside air to enter. Then take a flashlight and look in the vent and see if there is water inside. If there is water than that is your source.
Old Nov 30, 2007 | 07:15 PM
pinks11's Avatar
Default Re: Leak onto pedals and fuse box! (DAP91Si)
i have the same exact problem in my sedan... i still havent found the problem... it may be the windshield, because the seals do look loose, but i will most definitely check the firewall suggestion...
Old Nov 30, 2007 | 08:02 PM
Phshorty's Avatar
yeah mine leaks onto my hood latch, ill be sure to check the sunroof drain tubes when i replace the pannel with my new one :D also check all of your door and hatch seals, i replaced all of mine and my car dried up in a lot of places.
Old Nov 30, 2007 | 08:49 PM
danmdevries's Avatar
Default Re: (Phshorty)
I had the same problem too...
Mine was initially caused by a leaking antenna plate, or rather a missing antenna with an intact antenna plate, leaving a nice hole there. That lead to a much bigger problem.
Hope yours isn't as serious as mine was:
Old Nov 30, 2007 | 09:00 PM
JRZ88DX's Avatar
Default Re: (danmdevries)
i have an 88 DX
whenever it rains water gets into my trunk area.
Any idea as to where this could come from?
Old Dec 1, 2007 | 10:34 PM
Default Re: (JRZ88DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRZ88DX &raquo;</TD></TR><TR><TD CLASS="quote">i have an 88 DX
Any idea as to where this could come from?</TD></TR></TABLE>
Tail light gaskets.
Old Dec 1, 2007 | 10:38 PM
JRZ88DX's Avatar
ahh
thank you =]
Old Dec 8, 2007 | 06:07 PM
pinks11's Avatar
i have been experiencing a leak that leaks down thru my hood latch and all over my floor... my carpet all over the driver's side is completely soaked... i was just wondering if 1: Will this cause any rust or damage, and 2: Can I get the seals fixed instead of replacing the whole window??
uses0ap
Oct 1, 2006 11:24 AM
Unlimitationz
May 5, 2005 05:42 PM
Fl_civic_rider
Jun 25, 2004 11:36 AM
GroundZer0 336
Oct 26, 2003 07:43 AM
MooreBoost
Jun 24, 2003 11:31 AM
