Honda S2000 Honda S2000
s2000 trouble shooting p0302, misfire
Old Oct 14, 2007 | 12:21 PM
LumpyTheGrumpyCamshaft's Avatar
Default s2000 trouble shooting p0302, misfire
i have a 00 s2000 with 103k, after a week of somewhat heavy driving(no miss shifts/overrev, twice or so off 8k shifts) i got a cel. Scanned it and cly 1 and 2 missfire, general miss fire
The car also has had 2 bad sounding starts, but the car idles faily smooth and is fine threw out the powerband.
Anyone have suggestions as to what route i take with troubleshooting steps.
I changed the plugs after the very first day with the cel ,which at the time was only miss fire on cly2. I put in bosch +4, then had to retorqe them to 20lb, gonna try and check them tommrow.
I've also seen a lot of injector issues with 00/01's..
thanks
Old Oct 16, 2007 | 01:51 PM
Contraband's Avatar
I got this same cel, ended up being bent valves due to bad valve guides.
Old Oct 16, 2007 | 06:43 PM
RedstarS2K's Avatar
Default Re: (Contraband)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contraband &raquo;</TD></TR><TR><TD CLASS="quote">I got this same cel, ended up being bent valves due to bad valve guides.</TD></TR></TABLE>
Same things happen to me at only 36k miles, so dont drive it before doing a good check.
Old Oct 17, 2007 | 06:59 AM
Default Re: (RedstarS2K)
soo.. anyone know how i would start going about the troubleshoot proc,
comp test, then leak down test ? can i check the fuel filter or change that?.. etc
Old Oct 17, 2007 | 11:48 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (LumpyTheGrumpyCamshaft)
using Bosch's are your first problem. Go back to stock NGK's and you should be fine.
Old Oct 17, 2007 | 12:32 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">using Bosch's are your first problem. Go back to stock NGK's and you should be fine.</TD></TR></TABLE>
this man spits genius......bosch plugs FTMFL
Old Oct 17, 2007 | 01:43 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (GRAF-FITI)
^^ CORRECTO.. those +4 bosch
maddcrx
Honda S2000
14
Apr 27, 2021 11:13 AM
tuan...
Honda S2000
Apr 24, 2007 10:34 AM
michaelk
Dec 23, 2005 11:50 PM
michaelk
Honda S2000
Dec 13, 2005 09:21 PM
DVS2000
Honda S2000
22
May 26, 2004 08:22 PM
