what size fuel injectors should i run
ls integra, b18b1. the heads got crower cams and is rebuilt, bottom end is stock and im gettin a drag turbo kit. i wanna run 8psi. what size injectors would be best?
Considering your motor is probably stock & your vehicle is setup to run high impedance injectors. A set of precision 440cc or 525cc injectors would be the easiest to use.
If you plan on building the motor down the road etc... Go with a larger injector then you need such as an 880cc as previously suggested.
