worried bout burning oil :(
Old Oct 14, 2007 | 08:56 AM
xTimmyx's Avatar
Default worried bout burning oil :(
well ever since i got my car back from the body shop. i can smell...not see...smell. the engine burning oil.
it rarely happens, and its only on short spurts too. and it also happens when i'm at WOT.
i knew for a fact for sure that i had an oil leak on my dizzy, cause the o-ring was shot and there was oil all over the place. but now that i took it to a "mr lube" oil changer type deal, they said that i have an oil leak on my oil pan and head gasket.
so which leads me to see that the head gasket might be going.
also there is no smoke coming out the tail pipe either.
Old Oct 14, 2007 | 08:58 AM
DenzComp's Avatar
Is it dripping on your exhaust somewhere maybe?
You think you'd see smoke though somewhere if it was.
Old Oct 14, 2007 | 09:21 AM
Jonknee's Avatar
Default Re: (DenzComp)
What happened with me is it was leaking from my oilpan right below the Oil filter so it would drip slowly on my b pipe, but mine smoked.
Old Oct 14, 2007 | 10:00 AM
ridgeapd's Avatar
Default Re: (Jonknee)
agreed. check the oil seals at the oil filter area.
Old Oct 14, 2007 | 10:43 AM
Johnny-Red's Avatar
Default Re: (ridgeapd)
Check all the little things 1st, let it idle and see if u smell it and look to see if anythings dripping. pull the plugs, see if theres oil on any of them, im having the same problem with my d16, 1 plug was covered in oil i found my reason for the smell.
Its either rebuild the motor (if you have the time and resources), buy a new motor, or just run it till it dies and ignore and smells, booms, or metal to metal sounds
stephie1love
Aug 25, 2014 04:01 AM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
lanojp1
Sep 2, 2004 04:00 PM
diluted
Jan 17, 2004 07:54 PM
TurbothisLS
Feb 11, 2002 01:00 PM
