rev limit at 7.5
Old Oct 14, 2007 | 07:52 AM
outlawcry7's Avatar
Default rev limit at 7.5
i have an obd0 jdm b16a swap in my civic si with a pr3. i bought the car like that. and it also came with the apex'i neo. the thing is no matter what i do on the neo i cant raise the rev limiter. its limits the engine at 7500. its not that itll stop trying. itll just stay bouncing at 7500rpms like its the rev limiter. on both the tach and the neo. any idea on what the problem might be.
Old Oct 14, 2007 | 12:15 PM
Global688's Avatar
Default Re: rev limit at 7.5 (outlawcry7)
Tossing any CEL's? If not could be the ECU.
I have 2 PR3 ecus, one has the rev limit set at 7800 the other at 8200. Somone more knowledgeable might be able to explain this.
Old Oct 14, 2007 | 05:48 PM
outlawcry7's Avatar
Default Re: rev limit at 7.5 (Global688)
it gave me the code for the map sensor, tps, o2 sensor and crank sensor. i know the tps is bad because it makes the idle bounce, but even with it connected it wont rev passes 7500. so i just leave it disconnected until i can buy one.
Old Oct 14, 2007 | 06:23 PM
turbodcivic510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawcry7 &raquo;</TD></TR><TR><TD CLASS="quote">it gave me the code for the map sensor, tps, o2 sensor and crank sensor. i know the tps is bad because it makes the idle bounce, but even with it connected it wont rev passes 7500. so i just leave it disconnected until i can buy one. </TD></TR></TABLE>
wtf are you kidding me?
there you go!
TPS
MAP
crank angle sensor.
all those will cuase your car to run like ****. fix the issues at hand. im suprised that thing even idles.
Old Oct 15, 2007 | 06:42 PM
outlawcry7's Avatar
Default Re: rev limit at 7.5 (turbodcivic510)
just making sure. some people told me it couldve been my ecu so i wasnt sure. can i get the distributor, tps and map sensor for a b16a2 or a b17 and use it on mine with no problem?
Modified by outlawcry7 at 7:52 PM 10/15/2007
Modified by outlawcry7 at 8:07 PM 10/15/2007
Old Oct 15, 2007 | 06:48 PM
boosstboy's Avatar
Quote, originally posted by outlawcry7 »
after i stopped laughing----wow, im speechless.
Old Oct 15, 2007 | 06:50 PM
Ermil's Avatar
Default Re: rev limit at 7.5 (boosstboy)
Wow. Smart.
Old Oct 15, 2007 | 07:01 PM
outlawcry7's Avatar
lol. i know. my cars running shitty. im still learning whats wrong with the car. i bought it like that. but its for cheap so i cant complain. i know the tps is no good. especially because whoever did the swap damaged a wire. it doesnt read constant voltage on the neo. i forgot to mention they wired the fan to the distributor.
Old Oct 15, 2007 | 09:51 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawcry7 &raquo;</TD></TR><TR><TD CLASS="quote">lol. i know. my cars running shitty. im still learning whats wrong with the car. i bought it like that. but its for cheap so i cant complain. i know the tps is no good. especially because whoever did the swap damaged a wire. it doesnt read constant voltage on the neo. i forgot to mention they wired the fan to the distributor. </TD></TR></TABLE>
WTF?????
Old Oct 15, 2007 | 10:04 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawcry7 &raquo;</TD></TR><TR><TD CLASS="quote"> i forgot to mention they wired the fan to the distributor. </TD></TR></TABLE>
uuuhhhh
Old Oct 15, 2007 | 10:08 PM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawcry7 &raquo;</TD></TR><TR><TD CLASS="quote">i forgot to mention they wired the fan to the distributor. </TD></TR></TABLE>
Please, do go on...
Old Oct 16, 2007 | 09:28 AM
~sp33~'s Avatar
EFB055
Default Re: rev limit at 7.5 (Ermil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Wow. Smat.</TD></TR></TABLE>
Old Oct 16, 2007 | 05:18 PM
outlawcry7's Avatar
Default Re: rev limit at 7.5 (Bob_760)
im lucky if it didnt mess the distributor up. they also didnt tighten down the bolt on the shift linkage. when i was on my way from work my shift linkage fell off. i had no tools to put it back on but a vice grip and my hand.
cpennington89
Feb 20, 2015 05:33 AM
CRX_CRAZY07
May 15, 2007 09:58 AM
Crv-tec
Apr 15, 2006 11:05 AM
acurateggy93
Aug 15, 2005 10:36 PM
