car shuts off?
while idling for a while my car shuts off and while driving it just shuts off? I just bought a brand new distributor from acura, new spark plugs, wires, 02 sensor, fuel pump and filter. When it shuts off it will start right back up though. Last week i put in a new ignition fuse and that seemed to cure it for a week but now its doing it again. Any ideas?
ever fix this? having the same problem 98 gsr, car just shuts off, main relay replaced, fuel filter replaced, did test on tps which checked out, it will start up and run fine then when it idles at around 800 it will just out of no where shut off, if i have my hand on the throttle cable i can usually catch it and get it to rev and not shut off then after letting it idle down again it will eventually do it again, i need help!! daily driver
sw96
Oct 13, 2010 06:00 AM
ZedEx
Jul 1, 2005 01:41 PM
