timing issue
Old Oct 13, 2007 | 11:25 PM
kixcrx's Avatar
Default timing issue
ok so i bought a timing light to check my timing and i followed the steps that i read in other forums on how to fix the timing like jumping the connector and moving the dizzy while light is on pulley. but then i put the light on pully and see the marks and i noticed the marks aint even close to the pointer on the plastic cover i would move the dizzy back and forth and the marks arent even close to the pointer so then what could it be.
Old Oct 14, 2007 | 12:59 AM
kixcrx's Avatar
Default Re: timing issue (kixcrx)
could it be maybe that my cam is off by a tooth
Old Oct 14, 2007 | 01:02 AM
xanonymousx's Avatar
Was your car at full operating temperature? Also, I beleive your rpm's should be at ~750.
Old Oct 14, 2007 | 08:50 AM
kixcrx's Avatar
Default Re: timing issue (xanonymousx)
yeaH my car was at full temp im just going to take everything off and just put the cam and pulley to the center again
Old Oct 14, 2007 | 11:09 AM
kixcrx's Avatar
ok so i put everything like how it says in the haynes manuel to put the cam up with lines straight with side of the head and the pulley mark which is the white mark farthest from the other three alined with the marker on plaastix cover. But what i wanted to know is that i tightened every thing up and put the timing light and started messing with the distribuator moving it back and forth and the white line was perfect on the marker but the other three are still to far is this good or bad
builtsinglecam
Apr 24, 2009 02:50 PM
kaychi
Dec 7, 2006 02:13 PM
david90
Nov 18, 2003 10:09 AM
wantmorepower
Apr 16, 2003 09:52 PM
Lord Quaalard
Apr 3, 2003 10:33 AM
