skunk2 LCA and blox adj. endlinks help 95 civic hatch
does anybody have this combo. the hardware that came w/ the blox seems like it would not fit the skunk2 lca. can anybody help?
its cool i gave skunk2 a call and they helped me out. it turns out i had to use oem endlinks, but i'm gonna try and find smaller size scres for the blox endlinks.
i'll post pics once i'm done or if i get it done.
Good to know. Guess that knocks skunk2 off my list of possible lca's. Pretty sure I'm more than likely gonna go with mfactory, need to get ahold of them and find out if they'll work with the blox endlinks.
Make sure you put a sleeve around that smaller bolt where goes through the ball end or you're gonna create one rattling s.o.b. and some serious extra stresses...
i'm pertty sure u still can use the blox endlinks its just for the part that goes in the LCA that you would need 1 size smaller bolt and you'll have no prob. but w/ the skunk2 LCA all you need to do is screw the endlinks halfway or 3/4 of the way and no nut at the end. that is why they threaded it.
I take it F7 endlinks have the same issue as blox w/skunk2 lca? or no?
does anyone make spherical endlinks with 10mm lower bolt for LCA's?
OR
does anyone know the thread size of blox or F7? i found these in 10mm thread & 10mm ID for the bearing which is what we would need
Modified by 6SPD_EK at 10:55 PM 11/23/2007
Modified by 6SPD_EK at 10:56 PM 11/23/2007
OR
