infamous jerking during accel problem.
Old Oct 13, 2007 | 06:08 PM
s10cky's Avatar
Default infamous jerking during accel problem.
So I did a search on "car jerking" and came accross some interesting threads. A few of them were my exact problem. So chime in if you know the real cause.
There is no smoothness at all cruising on the highway. Its either on or off.
when accelerating, it jerks bad from 0-1500 rpms.
When cruising at any speed, when you left off of the pedal, it jerks and begins too slow down fast.
I have allread done the fallowing.
plugs, cap, rotor, wires. it is getting fuel. shooting a code 14, of which I cant seem too fix.
Old Oct 14, 2007 | 04:16 AM
s10cky's Avatar
ttt
Old Oct 14, 2007 | 06:32 AM
driftingindiego's Avatar
Default Re: (s10cky)
other than the code its throwing "code 14 IAC (EACV) - idle air control valve "
have you replaced your fuel filter lately?
Old Oct 14, 2007 | 08:32 AM
LstCivic's Avatar
Default Re: (driftingindiego)
I had the same problem with my ls powered civic and it turned out I had the wrong plugged in. If it is a dx car with mpfi one of the other plugs plugged right in. Make sure the wires coming off of it are blue and the other one is black IIRC.
Old Oct 14, 2007 | 08:56 AM
grog's Avatar
Default Re: (LstCivic)
my car did something like this when the FITV went bad, and if you have a cel 14 coming on, i would try to replace or clean the IAC. do a search on the IAC there a write up on how to clean these.
is your idle bouncing up and down?
Old Oct 14, 2007 | 10:09 AM
Max Kling's Avatar
Its the IACV.
When it dosent function you get horrible partial throttle, random holes, and other ****. There is a disable script for the IACV in Crome but you still run into all those problems. Check the connector at the IACV and see if your getting 12V and continuity to the ECU.
Old Oct 14, 2007 | 11:44 AM
ProSlow07's Avatar
Default Re: (Max Kling)
Could this be why when I first got my car it would idle way below the average speed and once I left off of the clutch/gas it gave me a severe jerking problem? I never checked the code but the CEL came on..
Old Oct 14, 2007 | 12:06 PM
Global688's Avatar
Default Re: (Deviant77)
Check out your TPS along with your IACV. Once my TPS was moved over to far and was shooting incorrect V to the ECU. Always fun to tap the gas pedal and nothing for 3 secs.
Old Oct 15, 2007 | 11:51 AM
s10cky's Avatar
OK. I just checked the iacv and its only getting 5 volts. the other side, which im guessing is a ground is getting 15 milivolts.
The tps is fine, atleast I think it is, ive adusted it and its at .5 and 4.5 volts at wot.
Old Oct 15, 2007 | 03:02 PM
s10cky's Avatar
BUMP. not getting 12 volts at all. I dont get it. I paid rywire too do it, something got fucked up.
can I run wires directly from the ecu?
Recklesszz
Jan 30, 2013 08:30 PM
jdmperspective
Aug 1, 2010 05:45 PM
LAO
Oct 12, 2007 04:01 PM
x11184
Aug 7, 2007 09:33 PM
.cingham
Feb 10, 2003 11:22 AM
