EF SEDAN QUESTIONS... PLEASE HELP!!!
Old Oct 13, 2007 | 04:15 PM
loudandlow's Avatar
Default EF SEDAN QUESTIONS... PLEASE HELP!!!
OK, so i just sold my eg hatch, and want to get an ef sedan! should i have any preference of the years? or are they all pretty much the same? now, my big question... can i put a JDM front bumper on the sedans? the one with the wrap around turn signal? or is that crx only? I think i'm going to get a red or gray one because i want the charcoal interior. also, i cant seem to be able to find a cat back for the sedan? thanks from a soon to be ef sedan newbie!
Old Oct 13, 2007 | 05:11 PM
The_Undertaker's Avatar
75.168.105.221
EF hatch is lighter and looks cool, like me.
Old Oct 13, 2007 | 05:28 PM
civiconfire's Avatar
get an ex 90 91 if you can, and 5 speed. the ex came with the si motor (a6) and mpfi. makes it more easy to do a swap. i like the 90- 91 because there are little things like the lights and moldings that look better.
i dont think the weight is going to be a problem... i had both hatch and 4 door. its almost the same.
Old Oct 13, 2007 | 06:21 PM
loudandlow's Avatar
Default Re: (civiconfire)
thanks civiconfire, that was exactly the info i needed!! a 90-91 ex it is! anyone have ideas about the jdm wrap around turn signal front bumper on a sedan??? can you put crx stuff on a sedan?
Old Oct 13, 2007 | 06:38 PM
janz3n's Avatar
Default Re: (loudandlow)
you can use the jdm hatch front end (has the wrap around turn signals) but you need fenders hood bumper and rad support if im not mistaken. the bumper will fit with the sedan fenders and hood but not as good as having all the stuff.
only difference with years in the sedan is really the front bumper , tail lights and some interior pieces like the cluster pod thingy lol. personally i like the 90-91 better. but im bias cuz i own one. you can also use a hatch cat back you just need to lengthen the tail pipe to clear the bumper. pretty sure no one makes exhuast for the sedan . theres other little things that are different from the hatch though ei. upper control arms(hatch's are shorter) and the ball joints on the sedan are a larger diameter.. kinda dumb
any questions feel free to pm me if you want. and you can also check this out (ef sedan squad) https://honda-tech.com/zerothread?id=1583747
Old Oct 13, 2007 | 09:03 PM
Cvic90's Avatar
Default Re: (janz3n)
the 88-89 don't have the motorized seat belts. I like my 88 alot better because of it.
Old Oct 13, 2007 | 11:06 PM
~sp33~'s Avatar
EFB055
Default Re: (The_Undertaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Undertaker &raquo;</TD></TR><TR><TD CLASS="quote">EF hatch is lighter and looks cool, like me.</TD></TR></TABLE>
You are the pinnacle of not cool. Looks are preference, if you want a sedan then go for it. The EX is not that much faster even though it does have that bit more hp, mainly because it has those few extra creature comfort features. I think the prefacelifted ones look better and you dont have the automatic seatbelts, but for comfort and Daily driving i'd get a 90-91 EX.
Old Oct 13, 2007 | 11:25 PM
loudandlow's Avatar
Default Re: (~sp33~)
Quote, originally posted by The_Undertaker »
Yeah, i'm pretty pissed this guy had to go and ruin my thread too... anyways, i want the power locks so i can wire them to an alarm and have key less entry, and a sunroof for ease of chiefin on the way to work and back. pretty sold on the 90-91 due to the a6 motor. to the best of my knowledge, which isn't much, the a6 has high compression pistons compared to other d series engines of the same year. please let me know if i'm completely wrong. haha, i plan on doing a mini me swap for the time being and i wouldn't mind the compression boost! again, correct me if i'm completely wrong
Old Oct 14, 2007 | 12:36 AM
turbodcivic510's Avatar
all you need is the JDM EF9 from bumper and it will bolt up, you dont need the fenders, hood, etc etc etc
goodluck and heres a teaser of my 4 door for you all.
Old Oct 14, 2007 | 05:48 AM
janz3n's Avatar
Default Re: (turbodcivic510)
^^^^already said this............. it will bolt up but there will be gaps
joeramlowlol
Feb 11, 2014 08:07 PM
EF K!d
Transmission & Drivetrain
Dec 26, 2013 10:11 PM
CORE132
Nov 23, 2010 07:31 AM
mrchevez
Nov 23, 2008 09:17 PM
1 point 6
55
Mar 15, 2003 08:29 PM
