will 94+ integra brake/clutch mc and ps pump work on my del sol??
Old Jun 20, 2002 | 06:52 AM
DeL SLo's Avatar
Default will 94+ integra brake/clutch mc and ps pump work on my del sol??
exactly as the topics states. will the 94-01 integra brake/clutch master cylinder and ps pump bolt right up to my 93 del sol si? if they do i can pick some up at a junk yard for super cheap and use that instead of buying new ones. i need to know asap, thanks.
Old Jun 20, 2002 | 06:55 AM
Spade's Avatar
Default Re: will 94+ integra brake/clutch mc and ps pump work on my del sol?? (DeL SLo)
The brakes will.....not sure about the PS.
Old Jun 20, 2002 | 11:15 AM
DeL SLo's Avatar
Default Re: will 94+ integra brake/clutch mc and ps pump work on my del sol?? (Spade)
kewl..im going to buy the brake mc from the junk yard next monday then. i prob wont be able to install it till way later, but its going to save me about 100-120 dollars from buying a new one.
i thought my clutch mc and ps pump was bad because this guy that i took to get it inspected say so. but i took it to another mechanic and he said it was ok. does anyone know if there is a sure fire way i can check to make sure the clutch mc and the ps pump are ok? i looked at it and their not leaking like the first mechanic said...soooo..??
Old Jun 20, 2002 | 01:29 PM
Solracer's Avatar
The Brake MC is differnt, I have a 94 integra ls and and 94 del sol si, they are differnt, it may be the same if it is an rs, i.e non abs.
AS far as telling if hte MS is good or bad, Put you foot on the brake and if is slowying depress with the same about of pressure then your MC is going bad.
[Modified by Solracer, 10:30 PM 6/20/2002]
Civic Racer X 7
Jul 2, 2014 01:42 PM
wishingiam
Suspension & Brakes
Mar 18, 2010 06:30 PM
wolf95
10
Jul 30, 2009 01:14 PM
itsmejto
Aug 7, 2008 03:10 PM
