Lots of parts wilwood, lakewood, skunk2, chips, etc w/pics
Lakewood Titanium traction bars, includes all the hardware, bebe size ding in bottom, with the hardware these weigh about 8 lbs! $OLD
Fast Brakes 12" 4 piston Wilwood front big brake kit, includes the stainless lines and all hardware, save 12 lbs over stock GSR brakes $OLD
JDM del Sol one peice head lights, mint, no broken tabs, come with city lights $OLD
Kyokogen Lugnuts 1.25 thread, silver, open top (new) $40
Skunk2 B-series cam gears $100
Halogen fog lamps (new) $10
B series unorthadox underdrive pulley (red) $30
http://www.fl-mr2.com/files/forsale/stuffs.jpg
Neuspeed black upper strut tower bar $50
Rear lower tie bar, black, looks like neuspeed $OLD
VTEC bar $25
(these all fit 92-00 civic, 94-01 integra, 93-97 del sol)
http://www.fl-mr2.com/files/forsale/bars.jpg
Benen 3 point front upper strut tower bar, and Benen rear bar $OLD
(fits 92-00 civic, 94-01 integra, 93-97 del sol)
Huge improvement in body regidity!!
OBD1 non-vtec d series engine harness uncut $40
92-00 civic windshield wiper motor $20
http://www.fl-mr2.com/files/forsale/dharness.jpg
92-95 d series vtec throttle cable with bracket $25
http://www.fl-mr2.com/files/forsale/dcable.jpg
92-00 civic stock shifter $15
http://www.fl-mr2.com/files/forsale/dshifter.jpg
OEM b series header (from GSR) $OLD
OEM d series header (from non vtec) $25
OEM d series header (from vtec) $35
OEM d series vtec top half header $15 (good for replacing a cracked one)
(all come with heatshields)
http://www.fl-mr2.com/files/forsale/manifolds.jpg
Various LCAs, UCAs, and endlinks from 89-00 $15 each
http://www.fl-mr2.com/files/forsale/suspension.jpg
90-93 b series axles brand new $100 pair
92-00 h22 swap axles brand new $150 pair
d series driverside axle in good shape, no torn boots $30
Appears to be a B series half shaft $40
http://www.fl-mr2.com/files/forsale/axles.jpg
1 pair of 90-93 integra OEM rear shocks and springs in good shape $30 pair
1 pair of 94-01 integra OEM rear shocks and springs in good shape $30 pair
http://www.fl-mr2.com/files/fo...s.jpg
94-97 Integra GSR master brake cylinder and booster $OLD
30/30 purportioning valve (for use with rear disk brakes) $20
http://www.fl-mr2.com/files/forsale/gsrmaster.jpg
h22 power steering pump w/mount and custom fluid line for H22 swap into EG, clears hood using factory connectors $OLD
Pair of ground control coilovers $30
(Fits 89-00 civic/crx, 89-01 integra, 93-97 del sol)
http://www.fl-mr2.com/files/fo...l.jpg
92-95 power steering pumps $25 each
99 b series power steering pump $25
90-93 ls power steering pumps $25
http://www.fl-mr2.com/files/forsale/pspumps.jpg
Tilt steering column $30
SRS unit with or without cruise $20 each
(fits 92-00 civic)
http://www.fl-mr2.com/files/fo...n.jpg
OBD1 D Series distributer $50
OBD1 LS distributer $50
OBD1 JDM H22a distributer $OLD
90-93 LS engine harness uncut $50
http://www.fl-mr2.com/files/forsale/lsharness.jpg
90-93 LS throttle cable $20
http://www.fl-mr2.com/files/forsale/lscable.jpg
92-97 del Sol driverside tail light $25
94-97 integra tail lights $40 pair
92-97 del Sol S cluster w/silver besel $35
90-93 LS front calipers, master cylinder, booster $70 all
various engine mounts and brackets, b, d, h series
full d series power steering set (all the lines and crap) $OLD
90-93 integra rear sway bar $20
94-01 integra power steering rack in good shape $85
94-97 del Sol dual core radiator with hairline crack in upper tank that can be repaired $10
94-97 del sol driverside rear disk brake setup $40
stock 92-00 civic radiator fan $20
OEM b series fuel pump $10
All prices are FIRM. email me if you are interested or have questions, or want a pic of something specific. bigboostin@gmail.com
I also have two used chipped eproms for any socketed honda ecu (P28, P06, etc). They are both tuned for an integra type r motor. (B18c5) They are both a basemap for basic bolt ons, stock internals, fuel injectors, etc. OBD1 setups. If your ecu is socketed, this is the chip that goes in it.
- Phearable.net $OLD
- Kenji w/9500 RPM limit, 6100 vtec engagement
$20 each, firm, mailed or picked up. I accept paypal.
Modified by H22AEG2 at 11:06 PM 11/7/2007
VTEC bar $25
(fits 92-00 civic)
whats the smallest wheel size you can run with those calipers? (wilwoods) and do they come with their own caliper bracket or do they fit on the gsr/si/ex one?
EDIT: sorry, i now see the brackets after lookin at the pictures
Modified by HatchEh2 at 11:18 PM 11/6/2007
b18bfreak
May 8, 2007 09:51 PM
