Pic wanted: CRX SI FMIC and bumber! what to cut?
How big is the IC? Depending on the size of it, you may just have to trim the rear side of the grill or cut it out. Also depending on the size of it, you may have to trim your bumper support.
Just cut whatever it takes to make it fit underneath...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">Just cut whatever it takes to make it fit underneath...</TD></TR></TABLE>
What he said. Every IC is different. Cut what you have to
Trial and error...every FMIC is a little different so you will need to trim it little by little till you get it to fit right....my IC is like 30"x6x2.5 and my cover is hacked fairly well...i didn't have to cut the metal bumper but if your is any taller you probably will..also if you have a 90-91 bumper you will mostlikely have to cut out the "fog light" vent things since you pipping will need some space there...
s0lefreshh
19
Apr 21, 2007 05:08 AM
RMXmitch
Dec 11, 2006 12:01 AM
