code 15
Old Oct 13, 2007 | 11:28 AM
boosted_17's Avatar
Default code 15
i got a 90 si crx with a ls and i have been trying to fix the problem i know what the code is it the ignitor output signal and i have alreay tried 3 different dizzys and a different ecu i am thinking that it might be in the wiring harness but i am not sure....i am down for trying anything but any help would be good
thanks
Old Oct 13, 2007 | 11:32 AM
VtecSyndrome's Avatar
Default Re: code 15 (boosted_17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_17 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 90 si crx with a ls and i have been trying to fix the problem i know what the code is it the ignitor output signal and i have alreay tried 3 different dizzys and a different ecu i am thinking that it might be in the wiring harness but i am not sure....i am down for trying anything but any help would be good
thanks</TD></TR></TABLE>
Did you reset your CEL after trying each new Dizzy?? it's been a while since I messed with that code but a new ignitor fixed it last time I had that code. You need to make sure your clear the code before trying another dizzy, otherwise it very well could be in your wires.
Kris's turbo
Mar 24, 2012 02:42 PM
kuteboi
Jan 29, 2005 09:11 PM
