90 si b16a throwing codes help
I have a 90 si with a jdm b16a, b16 ecu , and b16 tranny. The ecu is throwing code 17 code 10 and code 7. 10 is the speed sensor, the speed cable rolled out. so thats solves that. but code 17 and code 7??? The car is obdo imo.
It idles high when i first start it like 3000 rpm. I just got the timeing belt adjusted because it was coming off the front cam.( was missing the washer that holds it in place). Before i got it adjusted it would idle real low like at 400-500 rpms. now it idles at 3000 rpms than very slowly gos down to 1200 rpms. should i just adjust the idl? loosin tightin?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce »</TD></TR><TR><TD CLASS="quote">I have a 90 si with a jdm b16a, b16 ecu , and b16 tranny. The ecu is throwing code 17 code 10 and code 7. 10 is the speed sensor, the speed cable rolled out. so thats solves that. but code 17 and code 7??? The car is obdo imo.</TD></TR></TABLE>
wrong
code 17=Vehicle speed sensor
code 10= Intake air temp
code 7= TPS
wrong
code 7= TPS
