long block b20
hey i found a b20 longblock on password jdm for 525 dollars.. i was wonderin what exactly a longblock includes.. like if i bought that what else would i need to buy, like would i need to buy tranny seperate or does it come with one.. oh this is going into a 90 crx si.
Long block is typically a complete motor. As far a the trans you need to contact them. There is more to a swap than just buying motor. You will need mounts, depending on the car some wiring, linkage, and ECU.
yeah you would need a complete change over like tranny, ecu, axels, mounts and some wiring but you would need to get some new things like oil pump water pump timing belt because you wouldnt know how much longer they would last
