dose any one on this site have their car running on E-85
Old Oct 13, 2007 | 07:15 AM
95 honda8's Avatar
Default dose any one on this site have their car running on E-85
I did search this and found a lot but what I am wondering is dose any one on this site have their car running on E-85. and how do you like it? I have a 95 civic how can I make my car run on E-85? has any one ran nitrous on e-85,thanks for your help.
p.s. please don't post "that is a waste of time: or any thing like that. thank guys for all you help and if this as already been talked about if u could link me that would be great. thanks
Modified by 95 honda8 at 8:25 AM 10/13/2007
Old Oct 13, 2007 | 01:48 PM
Schister66's Avatar
Man U FTW
there are a few people i know of who had great success with E85....Mike @ SLS made 389whp on a stock B16
Old Oct 13, 2007 | 01:59 PM
ShawnR's Avatar
Default Re: (Schister66)
i know a little while ago i say some one make a post that they made 700 on e-85 i cant rember if it was in drag racing or fi.. do a seach for it
*edit*
did a seach for e85 and found the thread
https://honda-tech.com/zerothread?id=2073807
Old Oct 13, 2007 | 04:35 PM
96 GSR-T's Avatar
A friend is making 595 and 430 on E85 on only 21psi, daily driven EG.
Old Oct 13, 2007 | 08:31 PM
da_dude's Avatar
E85 user here.
Old Oct 14, 2007 | 05:56 AM
95 honda8's Avatar
Default Re: (da_dude)
what do I need to do to make my car run on e-85 (95 civic)?
Old Oct 14, 2007 | 06:05 AM
96 GSR-T's Avatar
Default Re: (95 honda8)
stock?, just switching to E85 isnt going to make you go warp speed, unless you are doing it for the environment, there is no reason for you to switch to it. Your car needs to be tuned on E85 otherwise just an aftermarket pump to be safe and a tank full of E85 is all you need.
Old Oct 14, 2007 | 06:11 AM
95 honda8's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">stock?, just switching to E85 isnt going to make you go warp speed, unless you are doing it for the environment, there is no reason for you to switch to it. Your car needs to be tuned on E85 otherwise just an aftermarket pump to be safe and a tank full of E85 is all you need.</TD></TR></TABLE>
some told me I needed to chage the fuel lines is this true?
Modified by 95 honda8 at 12:36 PM 10/14/2007
Old Oct 14, 2007 | 11:37 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by 95 honda8 at 12:36 PM 10/14/2007</TD></TR></TABLE>
No.
Old Oct 14, 2007 | 06:05 PM
base-op.1320's Avatar
Default Re: (Tippyman)
Basicly 28% more fuel (bigger injectors) and a good tune is all you need - my turbo car runs great on the e85.
Old Oct 14, 2007 | 06:49 PM
95 honda8's Avatar
Default Re: (base-op.1320)
thanks for all your help, but how do u think a 55shot of spry will do??
Old Oct 14, 2007 | 07:47 PM
SOHC_MShue's Avatar
Default Re: dose any one on this site have their car running on E-85 (95 honda8)
sigh...i wish they would bring it to my hometown
Old Oct 14, 2007 | 08:27 PM
You would have to make sure that you jet it 28% richer on the fuel, I wouldn't spray on e85 because of the inconsistent ethanol to gasoline mixture - if there mixture changes a little then you afr would also.
Old Oct 15, 2007 | 01:44 PM
Tippyman's Avatar
Default Re: dose any one on this site have their car running on E-85 (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">sigh...i wish they would bring it to my hometown </TD></TR></TABLE>
I know. I would love to let you tune my car on it when it's all finished.
Old Oct 15, 2007 | 02:02 PM
Schister66's Avatar
Man U FTW
with any luck, my next tune will be on E85...its all over Fargo and the surrounding area
Old Oct 15, 2007 | 09:11 PM
SOHC_MShue's Avatar
Default Re: dose any one on this site have their car running on E-85 (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I know. I would love to let you tune my car on it when it's all finished. </TD></TR></TABLE>
Heck yea man. I'm running 1000's on my setup now which are way oversized, but would be great for me if we had that E-85
Old Oct 16, 2007 | 02:43 AM
Tippyman's Avatar
Heck yea man. I'm running 1000's on my setup now which are way oversized, but would be great for me if we had that E-85 </TD></TR></TABLE>
1000's on your D?
Old Oct 16, 2007 | 08:51 AM
purpleh22's Avatar
H22, 92 hatch, 10:1 Arias, E85, GT30, Hondata, 950 injectors, 17 psi = 435 whp, 345 wtq. Fun street ride.
Old Oct 16, 2007 | 09:25 AM
projekt-sol's Avatar
Default Re: dose any one on this site have their car running on E-85 (purpleh22)
i ran e-85 in my silverado for a lil while.. but soon found out that it burn ALOT hotter then normal so i wont run it in my sol.. but like others said.. a good tune and bigger injectors is all u need
Old Oct 16, 2007 | 12:52 PM
96 GSR-T's Avatar
Default Re: dose any one on this site have their car running on E-85 (projekt-sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekt-sol &raquo;</TD></TR><TR><TD CLASS="quote">i ran e-85 in my silverado for a lil while.. but soon found out that it burn ALOT hotter then normal so i wont run it in my sol.. but like others said.. a good tune and bigger injectors is all u need</TD></TR></TABLE>
if it burns hotter, how does it lower EGT's and Coolant Temps?
Old Oct 16, 2007 | 02:59 PM
Default Re: dose any one on this site have their car running on E-85 (96 GSR-T)
It was probably way lean
circle22
Aug 17, 2013 09:00 PM
ahobbs
Oct 9, 2008 01:43 PM
matt56
Sep 3, 2006 08:21 PM
sheetsmusher
Apr 2, 2006 11:27 PM
gsrboosted
Nov 18, 2004 08:59 AM
