Can I convert my OBD1 valva cover to OBD2?
Old Oct 13, 2007 | 01:30 AM
Jabinya's Avatar
Default Can I convert my OBD1 valve cover to OBD2?
I'm in the process of building a B20 and while prepping my B20 cover I dropped it. Big crack along the left side. It had the hole on top for the PCV valve.
So I have a B18B OBD1 cover with no hole on top and was wondering if I can just drill a hole in the same place, install the PCV and still have it work properly. Anyone done this?
Modified by Jabinya at 5:52 AM 10/13/2007
Old Oct 13, 2007 | 12:35 PM
808DB1's Avatar
why not just use the exsisting hole ?
Old Oct 13, 2007 | 12:56 PM
Jabinya's Avatar
Default Re: (808DB1)
As you can see there is no original hole on the B18B valve cover, hence my question.
Old Oct 13, 2007 | 01:46 PM
lmike6453's Avatar
i have had the same problem when replacing my valve cover for my b18b1...what i did is cut the tube short on the intake manifold and put a breather on it...if you do this, just remember to leave the little piece with grooves on the the tube or when you start your car, it will idle at 2.75-3.25...ouuch
Old Oct 17, 2007 | 04:59 AM
lmike6453's Avatar
no air is being pshed through that hole you want to drill...air would only besucked in from the intake manifold
tougetuned_ef
Sep 16, 2010 03:38 PM
josh_db1
Aug 1, 2010 10:06 AM
candyman206
Sep 3, 2009 01:39 PM
candyman206
Sep 3, 2009 09:11 AM
povs9
Feb 26, 2007 07:52 PM
