LCA skunk2s or blox
Old Oct 12, 2007 | 11:06 PM
roycivic92's Avatar
Default LCA skunk2s or blox
u guys heard any stories about these. Im getting some lower control arms for my car , but cant deside. eg6
Old Oct 12, 2007 | 11:54 PM
doood's Avatar
been there done that
Default Re: LCA skunk2s or blox (roycivic92)
they're basically the same thing
Old Oct 13, 2007 | 12:11 AM
b20quang's Avatar
i heard the bushings in the blox lca don't hold up
Old Oct 13, 2007 | 12:31 AM
EJ1chevelle's Avatar
both would work great
Old Oct 13, 2007 | 01:34 AM
BlueIntegraBoy's Avatar
If you plan to add a sway bar later, I would get the Skunk2. The endlink hole is in a more correct position, plus the Skunk2 LCAs have poly bushings instead of the junk vulcanized rubber ones on the Blox.
Old Oct 13, 2007 | 04:43 AM
pythoner's Avatar
DON'T GET THE BLOX!!!
Can anyone read that it "helps correct negitive camber in lowered vehicles" that means that it reduces your track and that is not a smart move if you are looking for max proformance out of you suspention...In theory, it makes you rear skinnier and more prone to bad stuff
People should think of Pontiac's old commersials "Wider is better"
Old Oct 13, 2007 | 06:45 PM
roycivic92's Avatar
Default Re: LCA skunk2s or blox (doood)
skunk 2 it is, this is what i was looking for. bushing quality, fitment,performance. thanx
STN_Pat
Suspension & Brakes
27
Jan 23, 2010 03:48 AM
neroren
Jan 4, 2010 07:15 PM
JHPUSA
17
Jun 30, 2009 08:49 AM
Aventuraa
13
Apr 20, 2009 11:14 AM
SlowEJ8
Suspension & Brakes
25
Apr 8, 2009 07:26 AM
