distributor....do I need one from a 95 b18c?
Another ?problem? I have a 96 b18c1, and it's going into my 95 EX EJ. Do I need a 95 distributor or will the 96 work, plug right in with no problem?
TIA!
TIA!
if you are using the 96 harness you can use the 96dist.
I don't understand....use the 96 harness?
???doesn't the 96 distributor have more pinouts on the plug, thus having to use the less 95 b18 to match the 95 harness in the EX already???
help!
TIA!!!!
help!
TIA!!!!
if you use the 96 engine harness it all plugs up to the plugs on the shock towers, it is plug and play, i have a 97 motor in my 92 car and i used a 97 alt. and dist.
50trimmed
Mar 7, 2011 09:12 PM
