RCA: Stereo to Mono
Old Oct 12, 2007 | 05:43 PM
imadigitalgod's Avatar
Default RCA: Stereo to Mono
I am looking for a way to convert a pair of RCAs(left and right channel) to a mono channel, combining both channels, to make a center channel. I am wanting to do this at the RCA level.
I'm willing to build my own if there is a schematic out there
Any help is greatly appreciated
Old Oct 13, 2007 | 05:22 AM
slowSOHCvtec's Avatar
Default Re: RCA: Stereo to Mono (imadigitalgod)
just use a summing op-amp with unity gain, should give you what you need
Old Oct 13, 2007 | 10:36 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod &raquo;</TD></TR><TR><TD CLASS="quote">I am looking for a way to convert a pair of RCAs(left and right channel) to a mono channel, combining both channels, to make a center channel. I am wanting to do this at the RCA level.
Any help is greatly appreciated </TD></TR></TABLE>
why do you want a center channel?
Old Oct 19, 2007 | 01:23 PM
Default Re: RCA: Stereo to Mono (slowSOHCvtec)
Im trying to search the net for one but the op-amp summing circuits that i find require a + and - viltage input(not just positive and ground)
Old Oct 19, 2007 | 03:15 PM
02 accord's Avatar
Right RCA------/\/\/\/\/\--+----/\/\/\/\------Left RCA
........................10k........|.......10k
.....................................| &lt;- mono output
Combine the grounds together, run the signals through 10k resistors as shown, and there ya go.
Old Oct 20, 2007 | 11:14 AM
http://www.eng.yale.edu/ee-lab...8.pdf
check out page 9,
Also you will be able to find an op amp which does not use duel supply, just search mouser.com or another part store online.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Right RCA------/\/\/\/\/\--+----/\/\/\/\------Left RCA
Combine the grounds together, run the signals through 10k resistors as shown, and there ya go.</TD></TR></TABLE>
I'm not sure if this set up would work, wher edo you hook the ground of the RCAs to with this setup?
Fo-Do Fanatic
Audio / Security / Video
Oct 9, 2007 04:09 PM
mr poo
Apr 14, 2007 05:27 PM
sato108
12
Oct 5, 2004 04:16 PM
VizjereiAvatar
11
Jul 24, 2004 07:33 AM
crujones
Oct 2, 2003 06:58 AM
