buying a b16 head...
Old Oct 12, 2007 | 05:12 PM
iinvazionii's Avatar
Default buying a b16 head...
what should i look for when i'm buying a used b16a head? anything to take note of?
Old Oct 12, 2007 | 10:46 PM
daicacharco1513's Avatar
* B A N N E D *
take the valve cover off and inspect the internals
Old Oct 12, 2007 | 11:40 PM
numberone's Avatar
Default Re: (daicacharco1513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daicacharco1513 &raquo;</TD></TR><TR><TD CLASS="quote">take the valve cover off and inspect the internals </TD></TR></TABLE> Also check for bent valves or broken studs. Also check to see if it has ever been converted for Lsvtec( Had a friend burn up a motor that way!)
Old Oct 15, 2007 | 08:56 PM
B.J.'s Avatar
Default Re: buying a b16 head... (iinvazionii)
Alot of **** is fucked up on the internet so make so that you trust that person because it may not looked fucked up but when you take it to your builder he may tell you a vavle or some **** is bent
Old Oct 15, 2007 | 10:47 PM
My_EFsedan's Avatar
Default Re: buying a b16 head... (B.J.)
damn BJ, bumping every thread huh
besure to check that all valves are closed, not sticking out or anything..
Old Oct 16, 2007 | 03:56 AM
Dogginator's Avatar
Daisy... Daisy...
Make sure the cam caps are included and match the head. ALso measure the warpage and head thickness. I do not have the specs at the moment.
Old Oct 16, 2007 | 08:39 AM
nate_2k5's Avatar
Default Re: buying a b16 head... (Dogginator)
1.caps came with the head originally
2.no bent valves(unless you plan on replacing them)
3.no cracks in head casting
4.combustion chambers are not banged up from a possible dropped valve
cbabyby
Aug 21, 2010 12:09 PM
si90rex
Apr 8, 2008 08:41 PM
WHATS VTEC
Jan 24, 2004 10:10 AM
mafioso102
Jun 20, 2002 12:16 PM
