Timing Belt..... OEM vs. *?
ill be doing a mild build soon and i plan on changing the timing belt.
should i go aftermarket (toda, power enterprise, etc) or is a brand new timing belt good enough? im looking to spin to about 9500rpm and i need a belt that will hold.
go OEM. I've seen people slowly grind/tear teeth off of their cam gears because the toda timing belt was too strong. I would only use the toda timing belt if you were using other toda components (ie cam gears) connected to it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid 02 »</TD></TR><TR><TD CLASS="quote">OEM here. 9700rpm no problem.</TD></TR></TABLE>
12,000 RPM and no problem.
10,000 RPM Daily
10,000 RPM Daily
OEM, period...
you need the little stretch they give...
where as the greddy, toda, an PE stuff...is TOO strong and can even create bad harmonics...at least, a VERY reputable/popular/nut ridden engine builder told me over and over and over and over again for my 2.1L ITR swap build i had
hondakevin21
Jun 18, 2006 09:11 PM
lilxvtecxpwr
Apr 23, 2004 12:52 AM
