Where to buy some b series head flanges
Old Oct 12, 2007 | 11:29 AM
bigkvn77's Avatar
Default Where to buy some b series head flanges
hey,
I searched and nothing. Looking for ss but mild will work. thnx
Old Oct 12, 2007 | 12:25 PM
.adam.'s Avatar
bmcrace straighlinespecialties weirtech just to name a few
Old Oct 12, 2007 | 02:53 PM
bigkvn77's Avatar
Default Re: (.adam.)
thnx
Old Oct 12, 2007 | 05:21 PM
weiRtech's Avatar
OG Fabricator
i have many in stock. just click my sig.
Old Oct 12, 2007 | 11:54 PM
RC000E's Avatar
Default Re: (weiRtech)
I wish you'd do some 1/2" man. It's not necessary, but the anti-warpage characteristics are damn nice when your doing inside welds with no jig attached. I need some cheap 1/2" T3 flanges
Old Oct 13, 2007 | 05:11 AM
weiRtech's Avatar
OG Fabricator
i know. the reason i do everything in 3/8" though is because you can only laser cut holes in material that are larger in diameter or the same size that matches the thickness of the material... so for 3/8" thick flanges that means 3/8" holes. for 1/2" flanges, that means 1/2" holes... so i wouldn't be able to get small holes in all the 1/2" flanges and i'd have to drill all of them myself, which i don't have the time to do. also, i feel that 1/2" is not necessary. i've had no issues so far using 3/8" flanges.
Old Oct 13, 2007 | 06:08 AM
89crxhf's Avatar
what brand laser does the shop have? i have ran a few lasers and i have made several parts on them that had 3/8 holes in 1/2 steel. It can be done, i think the shop doesnt want to try it. It takes a little bit more time to so, when i had to cut parts like that i would pierce all the holes with the laser first then go back and cut them out. Doing it this way the heat from the pierce has had time to dissipate and should not cause problem when you go back to cut the holes.
Tom
Quada
Jun 10, 2010 06:18 AM
I Like Hondas
Dec 18, 2006 04:14 AM
dtown_racer
Oct 29, 2005 08:08 AM
Fab-Works
Welding / Fabrication
27
May 17, 2005 05:36 AM
Lamchop0000
Sep 11, 2002 11:04 PM
