a misfire problem
Old Oct 12, 2007 | 08:52 AM
pork's Avatar
Default a misfire problem
I have a 98 b18b in my civic coupe and I'm having a misfire issue.
Basically whenever I start the car after it was been warmed up (and sometimes on cold starts) the car misfires and it goes away once I start driving it which is kind of strange and doesn't ever misfire again until the car is turned off and back on. I changed the plugs so far but what else could be the problem?
Old Oct 12, 2007 | 08:57 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: a misfire problem (pork)
Take a look at your cap and rotor, maybe they need to be replaced, also if you have access to a timing gun, check your timing too.
Old Nov 11, 2007 | 12:44 PM
bigb16's Avatar
I would think that the spark plugs wires are bad. Just pull some off of a friends car, and try it out.
Old Nov 11, 2007 | 03:04 PM
AllMotor12s's Avatar
* B A N N E D *
Default Re: a misfire problem (bigb16)
i have the same problem but a lil worse underload the car seems like its runing on 3 cylinders. i change my entire dizzy plug wires and the plugs and even the fuel filter and i still have the problem
Old Nov 11, 2007 | 07:24 PM
ls19integra95's Avatar
Default Re: a misfire problem (AllMotor12s)
i had a smiliar problem and i tried, dizzy, cap, rotor, plugs. wires, fuel fitler and none fixed it i fixed the problem by replacing my o2 sensor so try that also...
Old Nov 11, 2007 | 08:05 PM
97integraLS911's Avatar
Default Re: a misfire problem (ls19integra95)
o2 sensor is most likely the issue if u have tried the distributor.. usually a dsitributor wont do that.. they'll just go out.. but sometimes they act up a lil first.
Good luck
Old Nov 11, 2007 | 08:20 PM
* B A N N E D *
Default Re: a misfire problem (97integraLS911)
aight truu kus for sum reason when i was at the track my car sounded like it was misfiring every thousands rpms like 6k 7k 8200 and that both wit old dizzy and the new one
lochenjons
Mar 11, 2012 04:46 PM
axionm1k
Apr 2, 2008 06:58 AM
tallguy
10
Aug 31, 2005 08:44 AM
ThatRicerDaniel
Feb 3, 2003 10:53 AM
SIK IN DA HED
Nov 19, 2002 04:32 PM
