Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Hood Ratles at high Speeds
Old Oct 12, 2007 | 06:06 AM
Killtodie's Avatar
* B A N N E D *
Default Hood Ratles at high Speeds
my hood latch is lose and so the hood ratles above 45 and makes an annoying noise.
how can i tighten up the latch or get it to stay closed better? There arnt any gaps when its closed, but the hood does give a little when you try to lift it.
does the whole latch need to be replaced or is there somewhay to tighten in?
Old Oct 12, 2007 | 06:37 AM
thinknology's Avatar
Default Re: Hood Ratles at high Speeds (Killtodie)
you may be able to adjust the tightness/ position of the mechanism...
Old Oct 12, 2007 | 10:17 AM
imroadk1ll's Avatar
i think u should do it quickly or ur hood might flip open wen going too fast. even though thats imposible itd be funny to see. try check y its loose.
Old Oct 12, 2007 | 11:08 AM
pow's Avatar
pow
Default Re: Hood Ratles at high Speeds (imroadk1ll)
better check on that asap. dont wanna worry you but there was one time i was riding in the passenger seat of my friend's car when the hood flipped and smashed the windshield. we weren't going very fast...probably 40KM/h. not sure what exactly caused the hood to flip, but it does happen.
Old Oct 12, 2007 | 11:36 AM
Killtodie's Avatar
* B A N N E D *
i stopped by a shop, the beam the connects the top frame to where the headlights and radiator are attached, the welds broke and the whole hinge is lose.
it shackes pretty crappy at 40mph.
i'll bungie it down for now, get it fixed later. $380 estimate
Old Oct 12, 2007 | 12:25 PM
fventura03's Avatar
why didn't you fix it? you're known for being an idiot and paying obscene prices for simple fixes.
Old Oct 12, 2007 | 12:44 PM
Killtodie's Avatar
* B A N N E D *
Default Re: (fventura03)
I cannot fix it myself.
I am not going to go to some cheap chop shop for repairs.
so what would you recommend?
Old Oct 12, 2007 | 02:18 PM
Syke Fu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">why didn't you fix it? you're known for being an idiot and paying obscene prices for simple fixes.</TD></TR></TABLE>
Ooooooooo.... Damn that was a low blow.
Funny!
But low.
Old Oct 12, 2007 | 03:36 PM
sil04ver's Avatar
Do our hood latches generally suck? Mine vibrates at idle and its annoying as hell. You cant really hear it outside but its noticeable inside.
Old Oct 12, 2007 | 03:47 PM
Killtodie's Avatar
* B A N N E D *
thanks for the awesome help
and replacing a clutch is a "simple" fix. yes.
Old Oct 12, 2007 | 03:56 PM
As2rd's Avatar
I have a shakey hood. Whenever I hit a bump, it vibrates like hell broke loose. My latch is as far down as it goes. Is there another way to fix this?
Old Oct 13, 2007 | 05:27 AM
GIXXERMAN83's Avatar
Default Re: (As2rd)
Is there another way to fix this?[/QUOTE]
Only way by fixing it is doing it the right way. Other "jerry rig" ways will only prolong the hood from samashing your windshield in and causing more damage, but hey its only your guys decision to fix depending how important you believe it is.
Old Oct 13, 2007 | 05:54 AM
Killtodie's Avatar
* B A N N E D *
well with me they need to replace that T brace or whatever.
its $380 because they have to remove the bumper and the radiator to get to it, so yeah, its called labor.
if you cant do it, pay someone else to. very simple.
while im at it, i'll probably have them replace the front bumper, its in terrible shape. inner shield is missing, its cracked, paint is fading and lots of nicks on it. will only cost another $300 for that
Old Oct 13, 2007 | 09:48 AM
Newborn_'s Avatar
Grace Under Pressure
LOL!!!
But true...
Old Oct 14, 2007 | 10:17 AM
As2rd's Avatar
I figured out that my hood has a bent "brace" on the the underside, causing the hood not to align and to shake even though it is fully latched. I think ill be fine, but will eventually get a cf and paint part of it.
Volkspeed
Apr 14, 2009 08:27 AM
Black Maverick
Jun 23, 2006 08:37 AM
kyle92integ
May 28, 2005 01:34 PM
t0ekn3e
Jul 9, 2004 11:27 PM
green98civic
Mar 16, 2003 01:23 PM
